Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.43 average. Display Modes
Old 06-05-2013, 12:34 AM   #701
cyberkaa
My Ride: E46 332i,M3;E30 325i
Originally Posted by crazyxzer0 View Post
Yes, thank you.
-Kalim
(klx photo studio)
Old 06-05-2013, 12:34 AM   #702
cyberkaa
Anyway, there's an S85 in the garage. Tear down coming soon.
-Kalim
(klx photo studio)
Old 06-06-2013, 12:40 AM   #703
hizhinezz
My Ride: 01 330i
Kalim's Garage Adventures
Originally Posted by VALMONT View Post
Kalim... live streaming garagecam!
Subscription info?
Also willing to do cameraman work as long as its after bedtime of chilluns and not during weekend daylight hours. Promise not to curse or foster vase thoughts (or at least try).
hizhinezz is offline   Reply With Quote
Old 06-11-2013, 04:05 AM   #704
cyberkaa
EuroCarFan's S85 Engine Tear Down!
As promised, here's the tear down analysis of Tony's old motor that left him stranded on the way to ECFest.
For background see Tony's thread here:
http://www.m5board.com/vbulletin/e60...89k-miles.html
After Tony was told that there were metal shavings in his oil pan, he was left with the sad news that he would need a replacement motor. I offered to inspect the motor to see the extent of the damage and determine if it was rebuildable. After a phone call to go over what exactly the tear down would entail and details on delivery, the motor was picked up from SonicMS in Mountain View, CA and brought over to my garage.
Picking up the motor from SonicMS
Already stripped of many parts...
Oil pan had a small leak from the front due to a hairline crack.
Loaded up into the delivery vehicle along with the SMG trans, which had the mounting tabs broken off.
Dropped off at my garage.
90-degree S85 V10 mounted on the stand.
Noticed some coolant seeping from thermostat housing. This was due to a hardened gasket. Common problem. The gasket fell to pieces when the housing was removed.
Oil pan off. Let's get to work.
The first order of business was to check the oil pump drive for damage. The VANOS oil pump looks normal.
The sprocket for the main oil pump was intact. There were no signs of failure here either.
The bottom end and oil still left in the engine looked fairly clean. Front half:
Back half:
Spot check of #4 rod bearing. The bearing is fairly worn and shows quite a bit of scoring.
That means the oil pump has to come off.
Another sign of trouble: oil pump pickup screen caught some metal shavings:
#1 rod bearing. The first sign of trouble here was that the bearing had turned springy and had to be pried off the crankpin. After it was removed, it was clear that the bearing was severely worn and no longer fit into the rod.
The crank was also scored from metal on metal contact.
The #2 rod bearing was similar (no pic).
This is the #3 rod bearing. It was similar to #4, showing wear and scoring. The #3/4 pair was the least worn pair of bearings in the motor.
#5 and #6 bearings. Severely worn and like the first pair, grabbed the crankpin and wouldn't fit in the big end of the rod anymore.
#7 and #8 bearings. Same story.
The #9 and #10 bearings were by far the worst in the motor. Both bearings were spun.
This is #9 after removing the end cap. The bearing shells rotated so the gap is 90 degrees off.
The #9 bearing and end cap were scorched.
#10 was almost as badly damaged.
And here's a video showing how much play there was in #9.
So the failure is similar to many others we've seen on the board. The good news is that the motor still looks rebuildable, but unfortunately it won't be as simple as replacing the rod bearings.
-Kalim
(klx photo studio)
Old 06-11-2013, 04:09 AM   #705
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Old 06-11-2013, 04:02 PM   #706
mkodama
mkodama's Avatar
Do not want S85.
Old 06-11-2013, 04:34 PM   #707
briangl92
My Ride: VQ37VHR
briangl92 is offline   Reply With Quote
Old 06-11-2013, 05:46 PM   #708
mcr_driver
My Ride: my favorite two feet
Sounds like a good candidate to rebuild...with the dinan stroker kit 5.8L of mother of god making 611 hp.... just sayin
mcr_driver is offline   Reply With Quote
Old 06-12-2013, 09:12 AM   #709
hizhinezz
My Ride: 01 330i
Originally Posted by mcr_driver View Post
Sounds like a good candidate to rebuild...with the dinan stroker kit 5.7L of mother of god making 630 hp.... just sayin
It he buys another engine, I'd live to source and do just that then drop into 330 w/manny tranny.
Old 06-12-2013, 09:33 AM   #710
tech9018
My Ride: BMW
How on earth did they bust the SMG mounts? Adds to the pain I suppose.
Is the crank salvageable? I've seen where you can have them regrind and smooth out the journals, and then use oversized rod bearings.
I think its time for one of these...
http://www.dinancars.com/shop/D850-1...ne.aspx#page=2
Its only $29,999 with a $20k core charge...
I'm sorry, $27,999... its on sale.
My Ride:
2001~2979cc~4 Doors~ZSP~Sunroof Delete~No Folding Rear Seats~Schwarz
Mods:
Dinan TB~Powerflex~Koni~Eibach~AA TwinScrew~
...And a whole lot of maintenance
tech9018 is offline   Reply With Quote
Old 06-12-2013, 11:35 AM   #711
cyberkaa
His car is already back up and running with another engine so this one is for sale.
-Kalim
(klx photo studio)
Old 06-12-2013, 11:40 AM   #712
cyberkaa
That trans came with the used replacement motor, which also had a cracked oil pan. I'm assuming it was either from an accident the donor car was in or it happened during shipping.
The crank looks salvageable with a grind and polish. It'll depend on the availability of undersized rod bearings.
-Kalim
(klx photo studio)
Old 06-12-2013, 12:21 PM   #713
mcr_driver
Old 06-12-2013, 02:50 PM   #714
mkodama
mkodama's Avatar
Very common on many BMWs for a crash to break the mounting tabs off. I've seen the exact same thing happen on E36 and E46 before.
Old 06-12-2013, 02:55 PM   #715
briangl92
My Ride: VQ37VHR
So why do the rod bearings go in the S85? Oil starvation at high RPM?
Old 06-12-2013, 03:18 PM   #716
cyberkaa
What it comes down to at the core is loss of oil film on the bearings.
The root cause behind that is unknown, but there may be oil supply issues. The pump still works fine, which is the interesting thing.
-Kalim
(klx photo studio)
Old 06-12-2013, 03:53 PM   #717
kwlaznkid
kwlaznkid's Avatar
My Ride: 335i/M3/CLK500
Send a message via AIM to kwlaznkid Send a message via Yahoo to kwlaznkid
do you do oil changes? I need my oil changed on my e60 m5
Need angel eyes or any lighting stuff installed in LA? PM me, cheapest around, I promise
BMW E64 650I
Mercedes Benz CLK500
BMW E46 M3 (SOLD) BMW E92 335I (SOLD) Porsche 996 911 C2 (SOLD) BMW E46 325Ci (TOTALED) BMW E92 328i (SOLD)
kwlaznkid is offline   Reply With Quote
Old 06-12-2013, 04:10 PM   #718
cyberkaa
lol, Jon. -___-
-Kalim
(klx photo studio)
Old 06-12-2013, 04:17 PM   #719
kwlaznkid
kwlaznkid's Avatar
Originally Posted by cyberkaa View Post
lol, jon. -___-
hehe
BMW E64 650I
Old 06-12-2013, 10:23 PM   #720
Bandit4077
My Ride: 330i SuperVeloce
Not a flaw, BTW, under normal wear this would be bad, but in a crash keeping a bunch of solid metal bits out of the cabin will save your skin. Many cars will have this designed into them for safety. It sucks if you want to pull a tranny from a wreck though.
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
epic
