Thread Tools Search this Thread Rating: Thread Rating: 67 votes, 4.99 average. Display Modes
Old 02-03-2013, 02:59 PM   #61
BringsMeWomen
My Ride: 2001 330ci
Subbed
BringsMeWomen is offline   Reply With Quote
Old 02-06-2013, 10:52 PM   #62
driftingSOCALE46
My Ride: 2002 325i
WRONG, not everything. (where is the DIY for engine removal).
Originally Posted by omarmarji View Post
DIY: Painting your exterior trim (without removing)
http://www.e90post.com/forums/showth...ghlight=window
DIY: Paint Your Interior Trim
http://forum.e46fanatics.com/showthread.php?t=798917
DIY: Replacing Door Hinge/Door Brake
http://forum.e46fanatics.com/showthread.php?t=351613
DIY: Painted Kidney Grille
http://www.bmw-m.net/techproc/grill.htm
DIY : Secondary Air Pump & Valve
http://forum.e46fanatics.com/showthr...ht=diy+seafoam
DIY: Stay Genuine And Enjoy Shorter Shifts
http://forum.e46fanatics.com/showthr...rt+shifter+diy
DIY: CDV Delete
http://forum.e46fanatics.com/showthr...hlight=diy+cdv
DIY: Change fuel injectors on a E46 325
http://forum.e46fanatics.com/showthr...do+it+yourself
DIY: Oil Change
http://www.my330i.com/lof.php#H
DIY: Factory Alarm Kit
http://www.my330i.com/mod8.php
DIY: BMW AUX AUDIO INPUT KIT
http://www.my330i.com/mod26.php
DIY: 12V Auxiliary Power / Secondary Cig. Lighter Under $10!!
http://forum.e46fanatics.com/showthread.php?t=791932
DIY: Grilles, Windshield Wiper Tank, Custom USB charger
http://forum.e46fanatics.com/showthr...967&highlight=
DIY: Refinish/Restore Curb Rashed wheels
http://forum.e46fanatics.com/showthr...071&highlight=
DIY: Sedan Rear Bumper Removal/Installation
http://forum.e46fanatics.com/showthread.php?t=358017
DIY: CF Roof Install
http://forum.e46fanatics.com/showthread.php?t=483306
DIY: Fender Rolling
http://forum.e46fanatics.com/showthread.php?t=598528
DIY: Complete M3 OEM Mirror Retrofit for the E46 Sedan
http://forum.e46fanatics.com/showthread.php?t=675377
DIY: E46 M3 mirrors retrofit onto E46 sedans/wagons instructions
http://www.rogueengineering.com/Merc..._Code=E46M3MIR
DIY: Convertible Top Interior Trim Flap Repair
http://forum.e46fanatics.com/showthread.php?t=520323
DIY: Dash Removal / Replace
http://forum.E46Fanatics.com/showthread.php?t=628898
DIY: OEM illuminated gear knob installation
http://www.argyrides.eu/bmw/accessor...knob/shift.htm
DIY: Cluster LCD replacement
http://forum.e46fanatics.com/showthread.php?t=670689
DIY: Shift Style alcantara Shift Boot / Ebrake Boot install
http://forum.e46fanatics.com/showthread.php?t=786558
http://forum.e46fanatics.com/showthread.php?t=751751
DIY: CCV, DISA, ICV, Oil Separator
http://forum.e46fanatics.com/showthread.php?t=643639
DIY: Brake Rotors and Pads
http://forum.e46fanatics.com/showthread.php?t=410638
DIY: Oil Level Sensor
http://forum.e46fanatics.com/showthread.php?t=366659
DIY: Front Control Arm Bushing (FCAB)
http://forum.e46fanatics.com/showthread.php?t=140066
DIY: Front Control Arms
http://forum.e46fanatics.com/showthread.php?t=421918
DIY: PowerFlex Rear Trailing Arm Bushing RTAB DIY
http://forum.e46fanatics.com/showthread.php?t=678004
DIY: Replacing Rear Differential Bushings Mounts
http://forum.e46fanatics.com/showthread.php?t=521636
DIY: 5 to 6 Speed Swap
http://forum.e46fanatics.com/showthread.php?t=574363
DIY: neil1138's 5 Speed Swap - Great information on the parts and process of the swap
http://forum.e46fanatics.com/showthread.php?t=659314
DIY: Power Steering Pump
http://forum.e46fanatics.com/showthread.php?t=575499
DIY: UUC Under Drive Pulley Install
http://forum.e46fanatics.com/showthread.php?t=483472
DIY: EMP Stewart Water Pump + Expansion Tank + Deflector Pullies + Coolant Flush
http://forum.e46fanatics.com/showthread.php?t=634490
DIY: Differential Swap
http://bokchoys.com/differential/diy_diff.htm
DIY: 02 Simulator install
http://forum.e46fanatics.com/showthread.php?t=654222
DIY: Installing Adjustable Lower Control Arms
http://forum.e46fanatics.com/showthread.php?t=675565
DIY: Intake boot replacement
http://forum.e46fanatics.com/showthread.php?t=754766
DIY:Angle Eye Install
http://www.fastm.com/m3/angeleyes.html
DIY: Corner / Parking Light Delete
http://forum.e46fanatics.com/showthread.php?t=278132
DIY: Corner / Parking Light Delete - without risking damage
http://forum.e46fanatics.com/showthread.php?t=694015
DIY: Taking your headlight apart (excludes facelift coupes)
http://forum.e46fanatics.com/showthread.php?t=609558
DIY: Headlight removal for facelifted coupe
http://forum.e46fanatics.com/showthread.php?t=639475
DIY: Changing Xenon Bulbs on 04+ coupe
http://forum.e46fanatics.com/showthr...66#post8288566
DIY: Changing Xenon Bulbs on all e46 models (except 04-06 coupes)
http://forum.e46fanatics.com/showthread.php?t=609544
DIY: Installing LED interior lights
http://forum.e46fanatics.com/showthread.php?t=640683
DIY: Parrot Bluetooth using Connects2
http://www.bokchoys.com/differential..._bluetooth.htm
DIY: OEM Navigation Retrofit Guide
http://forum.e46fanatics.com/showthread.php?t=203145
DIY: Build Your Own Paddle Shift Kit
http://forum.e46fanatics.com/showthread.php?t=56234
DIY: Build Your Own Paddle Shift Kit - For an X5
http://forum.e46fanatics.com/showthread.php?t=63211
DIY: BMW 16:9 Widescreen NAV Retrofit
http://forum.e46fanatics.com/showthread.php?t=121982
DIY: Carputer
http://forum.e46fanatics.com/showthread.php?t=409009
DIY: Inspection II walk through
http://www.bimmerfest.com/forums/sho...d.php?t=109846
DIY: Fuel Filter
http://forum.e46fanatics.com/showthread.php?t=265683
DIY: Oil and Engine Service Light Reset for 99-00 e46 - OBD I
http://forum.e46fanatics.com/showthread.php?t=145270
DIY: Post-Cat O2 Sensors + Pre-Cat O2 Sensors
http://forum.e46fanatics.com/showthread.php?t=293116
DIY: Camshaft Sensor
http://forum.e46fanatics.com/showthr...ghlight=sensor
http://forum.e46fanatics.com/showthr...sensor+exhaust
DIY: ATF Flush
http://forum.e46fanatics.com/showthread.php?t=438667
DIY: Coolant Flush
http://forum.e46fanatics.com/showthr...ht=coolant+DIY
DIY: Belt Replacement
http://forum.e46fanatics.com/showthread.php?t=522832
DIY: Blower fan
http://forum.e46fanatics.com/showthread.php?t=418987
DIY: Rear Wheel Bearing on the Cheap
http://forum.e46fanatics.com/showthread.php?t=581164
DIY: E46 Front Wheel Bearings
http://forum.e46fanatics.com/showthread.php?t=610725
DIY: Manual Transmission Fluid Change
http://forum.e46fanatics.com/showthread.php?t=491209
DIY: Oil Change
http://forum.e46fanatics.com/showthread.php?t=483444
DIY: Made non-folding, OEM M3 mirrors auto fold
http://forum.e46fanatics.com/showthr...&highlight=diy
DIY: Sub installed in ski pass
http://forum.e46fanatics.com/showthr...ht=sub+install
DIY: How To Remove And Install Cams Without Any Special Tools
http://forum.e46fanatics.com/showthread.php?t=799650
DIY: Remove Alternator..Auto-Trans..no need to remove fan. Red Battery light
http://forum.e46fanatics.com/showthr...190&highlight=
DIY: Final Stage Resistor - Cabin Fan controller
http://forum.e46fanatics.com/showthr...&highlight=fsr
DIY: ZKW-R lens into Bosch/AL Bi-xenon projector
http://forum.e46fanatics.com/showthread.php?t=801408
DIY: DIY Flex Disc (Guibo)
http://www.bokchoys.com/differential/diy_guibo.htm
http://www.bokchoys.com/differential/diy_diff.htm
DIY: E46 Rear Brake Job
DIY: E46 3 Series Cabin Air FIlter Replacement
DIY: E46 Valve Cover Gasket Replacement
DIY: Spark Plug Removal and Installation
DIY: BMW E46 Spark Plug Boots
DIY: Airbox Removal
DIY: BMW E46 Gauge Cluster Removal
DIY: Checking / Adding Coolant on a BMW
DIY: BMW Oil Mileage Service Reset
DIY: E-46 AWD FRONT AXLE SWAP
DIY: E46 Sock Mod DIY
DIY: BMW 3 series (E46, E36) dashboard test
driftingSOCALE46 is offline   Reply With Quote
Old 02-20-2013, 08:52 PM   #63
stuntin325
My Ride: 2001 325
We need a heated seats retrofitdiy
Sent from my HTCEVOV4G using Bimmer App
stuntin325 is offline   Reply With Quote
Old 02-20-2013, 09:03 PM   #64
Sansho
My Ride: 2001 325i
Search, it's been done before.
Sansho is offline   Reply With Quote
Old 02-24-2013, 12:28 PM   #65
Japanrot_325i
My Ride: 03 325i
Vanos oil line DIY ?
Japanrot_325i is offline   Reply With Quote
Old 02-24-2013, 12:38 PM   #66
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Disconnect two bolts.
Reconnect two bolts with new crush washers and new line.
DIY complete.
Next ill be making the turn on the radio DIY
Old 02-24-2013, 02:07 PM   #67
Japanrot_325i
My Ride: 03 325i
DIY complete.
Well yea I knew it was that easy. I just thought seeing some pictures might be helpful. Never done it before but thanks. Ill be highly anticipating your turn on the radio DIY.
Old 02-24-2013, 08:52 PM   #68
peytonracer4
:D
My Ride: '00 328i
It's very very easy. The only hard part is getting enough leverage to get the rear bolt off. But even that seemed very easy. If your hands are small you're golden.
Old 02-25-2013, 07:50 AM   #69
Japanrot_325i
My Ride: 03 325i
Well I'm screwed I have bear paws lol. Thanks for the insight though plan to change that and my ofhg during my next oil change.
Old 02-25-2013, 04:24 PM   #70
omarmarji
Banned User
My Ride: E36 332i
done!!
omarmarji is offline   Reply With Quote
Old 02-25-2013, 04:25 PM   #71
omarmarji
Banned User
My Ride: E36 332i
HEATED SEAT AND POWER SEAT RETROFIT
http://forum.e46fanatics.com/showthread.php?t=348165
Old 02-25-2013, 05:39 PM   #72
peytonracer4
:D
My Ride: '00 328i
Then you're in luck because the rear bottom bolt is connected to the oil filter housing as far as I know. So just disconnect the top bolt and then pull it off with the filter housing
Old 04-16-2013, 08:37 AM   #73
clarkson23
My Ride: 325i
nice
clarkson23 is offline   Reply With Quote
Old 08-18-2013, 02:56 PM   #74
YOnpds
My Ride: E46
Great job OP and others that are contributing!!!
YOnpds is offline   Reply With Quote
Old 09-07-2013, 11:16 AM   #75
vsbecks
My Ride: 325i
hi , i need some help!!!! my 325i has been heating up of late. So naturally i started with a process of elimination . i started with a change of the hoses, blower motor, thermostat change and i bleed the system . By doing all the changes i thought i had fixed the problem but when i decided to the take the car for a spin the engine started heating up and i had to stop several times to let it cool off before i could top off the coolant . i also noticed that my fan is not kicking on to cool the engine , and that when i run the car with the hood open it does not overheat for over 30 minutes . someone please help!this problem is crippling me !!
vsbecks is offline   Reply With Quote
Old 02-04-2014, 05:56 PM   #76
dekelley1
My Ride: 2001 BMW 330ci
Engine Swap DIY?
I blew my engine and would love a engine Swap DYI. Anyone live in western WA that would like to help. Looking to do it in March.
dekelley1 is offline   Reply With Quote
Old 09-07-2014, 11:00 AM   #77
cwspeakman
My Ride: e46 3251
Exclamation auxiliary fan issues
I got in a wreck in my 2001 325i put back together but in the crash the wires that got to the little black box that sites on top of the radiator fan shroud it has four wires yellow and brown and blue and brown I know the yellow goes to yellow and blue to blue it's the brown wires that I'm not sure of figured both would be ground but the one with blue wire is reading .05v and the blue is reading .5v the other set brown is reading 0v and yellow is reading 5v any help would be awesome just not sure if they are hooked up right thanks
cwspeakman is offline   Reply With Quote
Old 09-07-2014, 11:50 AM   #78
happyfelthappy
My Ride: 2001 BMW 330i Sport
@vsbecks: Did you check the aux fan to see if it turns on? and also if there is a ton of debris covering your radiator or a/c condensor it wont let air into your engine. So when you leave your hood open a bit, it lets more air in and keeps it cool.
@cwspeakman: do you need a picture of the plug with the wiring? I have a 2001 330i I think these are all the same plug and wiring though.
Previous Cars:
95 Nissan 240SX Auto -First Car :) / 91 Camaro RS 5.0 Manual / 99 BMW 323i Manual / 1984 Porsche 944 / And others..
Current:
2001 BMW 330i M Tech I Sport / 2001 Jaguar XJ8 L 4.0 V8 (Daily, gas guzzler)
Parts wanted '01 330i
-Electric Fan -Windshield Cowl -Front lower control arm bushings -Air intake manifold (on radiator support) -Oil level sensor
happyfelthappy is offline   Reply With Quote
Old 09-07-2014, 12:04 PM   #79
cwspeakman
My Ride: e46 3251
if you could in the wreck the wires going yo the black box on top of the radiator shroud got cut just not sure about the brown wires because one shows voltage and the other don't just don't know what brown wire goes to which yellow or blue one
Old 09-07-2014, 01:22 PM   #80
happyfelthappy
alright i will post it later today, im heading to see my car in a bit. still at my shop while i get things fixed on it.
Previous Cars:
Current:
