Sponsored by BimmerWorld
Old 10-19-2010, 09:39 AM   #1
GA-e46
My Ride: 2001 325i
shaking while braking
hey guys, my brother has a 2001 330 5spd. when you hit the brakes around 30+ the wheels start to shake left to right and then it pulls to the right. he recently had his brakes done about a month ago, but i suggested it was a warped rotor. he replaced his F-CAB's yesterday and the car still shakes violently when breaking. any help would be appreciated as this is his daily driver.
GA-e46 is offline   Reply With Quote
Old 10-19-2010, 09:41 AM   #2
The-Traveler
My Ride: 2004 330Ci ZHP
Tie rods can cause this. I would change them and get the car aligned. If you've already done the FCABS, this should help a lot.
The-Traveler is offline   Reply With Quote
Old 10-19-2010, 12:09 PM   #3
hummer
My Ride: 2001 330CI
Aside from bad brakes, could be tires worn from bad FCABs, struts gone, ball joints gone then maybe tierods. How many miles on these parts? Did the problem only start after the new brakes?
Old 10-19-2010, 12:28 PM   #4
GA-e46
My Ride: 2001 325i
the car has 130,xxx miles on the suspension without any replacements as far as i know. im gona say the shop that replaced the F-CAB's would have the car on a lift and a they would have stated if a strut was blown since it would be easily visible. the problem began after he had the brakes done. soon after there was a bad rain storm which leads me to believe he hit a puddle which warped the rotors.
Old 10-19-2010, 12:32 PM   #5
RHLP3
My Ride: An office chair
Sounds like warped rotors to me?
If we leave by midnight...
RHLP3 is offline   Reply With Quote
Old 10-19-2010, 01:29 PM   #6
TrippinBimmer
My Ride: Just Fast!
Make sure he dont have Sticky Caliper that will cause warp rotors...
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 10-19-2010, 01:38 PM   #7
Zero2_2005
My Ride: 328i
I had a sticky caliper that did this. It was my front left one and when i braked it wobbled like crazy and pull to the left. The front left wheel was unusually hotter than the other three wheels on the car after hard driving and braking when touched. It could be anything so take your time to diagnose the problem and get it fixed.
Zero2_2005 is offline   Reply With Quote
Old 10-19-2010, 02:24 PM   #8
GA-e46
My Ride: 2001 325i
Zero that sounds exactly like what is happening. what exactly is a "sticky caliper"?
Old 10-19-2010, 02:29 PM   #9
TrippinBimmer
My Ride: Just Fast!
Sticky Caliper is when ur Caliper will not move to neutral point of state. So the Pads will not come into contact. It is recommend that u rebuild or replace with a Reman Caliper.
-TrippinBimmer
BTW: The Pads and Rotor are toasted. Will need to get them Turned or Replace with new Parts
Alpine White M3
MaximumPSI Stage4
