Temp gage low, and heater not working - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-20-2010, 06:13 PM   #1
marzman
My Ride: e46 328 Coupe
Hi all,
Sorry to ask a question, but have searched for ages and cant find an answer...
Basically, i've got a 125k mile 323ci, which has a full service history.
However, i have 2 problems, which i suspect could be related.
1. My Temp gauge only intermittently goes to the vertical position, but the majority of the time remains int he cold section.
2. My heater in the car will not blow hot air. No matter how warm i set the temperature, i cannot get hot air out of the blower (and yes i've set it to the red dots etc). However, it does seem to feel slightly warmer when i have the AC on...!
There are no fault lights on the dashboard.
So, my assumption is that the Thermostat needs replacing... would i be correct in thinking this?
marzman is offline   Reply With Quote
Old 10-20-2010, 06:33 PM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Yes, absolutely correct. Therm stuck open...search for that and you'll find these symptoms.
I had that...didn't have an issue much with heat, but suppose that's an issue of how stuck open it is too, and mine prolly also happened in the spring/fall if I recall...so maybe wasn't noticing heat wasn't so hot.
HTH
Doug
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 10-20-2010, 06:49 PM   #3
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Yes thermostat stuck open is the problem - agree with dmax. I also had this but was throwing a code that indicated exactly that. I also experienced my heat not getting as hot as it should, and mine was also intermittent. My system never overheated but it did stick open sporadically.
If you DIY this, and it is a very easy DIY, let the system come up to temperature while driving around and pay very close attention to the temp gauge. I did mine, swore that the hoses were firmly in place after the procedure only to find out that one of the clips didn't fully seat, which caused a minor overheating condition and some more time working on the car.
GL
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 10-20-2010, 07:17 PM   #4
marzman
Thanks men.
I'll have a look for a DIY and then get it sorted.
Cheers
Chris.
Old 10-20-2010, 08:22 PM   #5
Lusticles
My Ride: 325Ci
Yeah its the thermo. I get heat -- just not out of the middle vents. Top and bottom vents spew out heat, as do my defrosters. However if I turn on the middle vents, no heat.
number one Audi Fan
Lusticles is offline   Reply With Quote
