E46 Xi Forum
Old 10-22-2010, 08:05 PM   #1
Glissco27
My Ride: is a smoked Xi
Send a message via AIM to Glissco27
suspension help
Hey guys so after doing some reading about shocks/struts etc i started thinking about if mine need to be changed...i got my xi at 40,000 and its currently at 72,000..to my knowledge the shocks have never been replaced. you guys think i should maybe invest in new shocks? if so, what do you recommend. sounds like i should either go with Bilstein sports or Koni Yellow. Since we're on the subject maybe you guys could recommend springs as well and anything else i might need. Thanks for the help
Glissco27 is offline   Reply With Quote
Old 10-26-2010, 09:19 AM   #2
slimwest1
My Ride: 330xi
I can tell you that my rear passenger spring broke recently at 63,000 miles so I had to do something. My car doesn't take the bumps like it use to so I'm replacing the springs, struts/shocks at all four corners tomorrow. I'm going with the Bilstein HD's and the Eibach Pro-kit for the springs. I know it will be a little harsh as compared to the original setup but I doubt that my current struts/shocks have much life left in them anyway. I'll let you know how everything goes after tomorrow.
slimwest1 is offline   Reply With Quote
Old 10-26-2010, 02:05 PM   #3
Rickna
My Ride: '01 330xi - '09 IS-F
I had both rear springs crack. I went with Eibach Pro's & Koni Adjustables. The drop is about 1" or so. Very close to the original ride.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-26-2010, 03:18 PM   #4
Glissco27
thanks guys, sounds like the eibach pros and konis might be the way to go for me, im looking for a nice drop in height...thanks
Old 10-26-2010, 04:11 PM   #5
jn8691
My Ride: awd&loud
go with the h&r sport springs if you want more performance than the eibachs, stiffer, lower, etc.
jn8691 is offline   Reply With Quote
Old 10-26-2010, 04:26 PM   #6
Glissco27
what kind of shocks do you recommend?
Old 10-26-2010, 05:32 PM   #7
Rickna
I was told that H & R and Bilstein for performance - Eibach and Koni for ride quality.
2001 BMW 330xi
2009 Lexus IS-F
Old 10-26-2010, 05:54 PM   #8
xi_ter
My Ride: 2003 325xi
At 72,000 mi your shocks likely wore out 22,000 mile ago. It would be no surprise if your factory springs are broken as well (mine broke at 35,000 miles).
For a great ride and adjustability go with Koni Sports and Eibach Prokit Springs
Improves the look of xi s a lot
Made sure you get an alignment right after so the CV joints don't get stressed.
Old 10-26-2010, 06:52 PM   #9
Glissco27
xi ter, how would i know if they wore out? i havent noticed a change in my ride/performance and dont see or notice for that matter any leakages is there another way i can tell if i crawl under the hood?
Old 10-26-2010, 10:20 PM   #10
xi_ter
My Ride: 2003 325xi
The degrade happens over the space of 70,000 miles so it's hard to notice. Mine weren't leaking either, but when I took them off, I could move the piston up and down by hand. You might look for diving during sudden braking, noises, other suspension components starting to wear rapidly, uneven wearing of tires.
After 50,000 miles design life, the original shocks owe you nothing. If you do buy replacements, inspect the old ones during shock replacement DIY and leave the old ones on for a year if they are good. Expect after 72,000 mi the shock will probably move up and down in your finger tips, completely worn out.
Old 10-26-2010, 10:27 PM   #11
Glissco27
alright, thanks for your help
