E46 Xi Forum
Old 10-23-2010, 04:33 PM   #1
surf2salsa
My Ride: 2003 325xi Sedan
No drop after Eibach's w/Koni's on 325xi?
I've just installed Eibach's and front Koni's on my 2003 325xi (rears on backorder).
I'm looking at the car and it seems to be about the same height.
Here are before and after pics.
Before:
ID:	380951   Click image for larger version
ID:	380952   Click image for larger version
surf2salsa is offline   Reply With Quote
Old 10-23-2010, 04:34 PM   #2
surf2salsa
And after the installation:
I don't see much difference. What could be wrong?
ID:	380954   Click image for larger version
ID:	380955   Click image for larger version
ID:	380956   Click image for larger version
Old 10-23-2010, 04:39 PM   #3
tb330
My Ride: 2006 Acura TL
I'm not sure how the Koni's would effect the height as I'm still on stock shocks, but when I lowered with Eibach's I ended up getting a small drop. It will drop a little bit more after it settles, but your car will still have some wheel gap.
tb330 is offline   Reply With Quote
Old 10-23-2010, 05:41 PM   #4
Slowlane22
My Ride: 330xi
Your before and after shots look just like mine did after I installed my dinan suspension. I can see a drop now, and it'll take 10-15 days for the suspension to settle to its final ride height. Don't worry about it. Looks great, grats!
Slowlane22 is offline   Reply With Quote
Old 10-23-2010, 06:04 PM   #5
surf2salsa
Thanks, do you have any pics?
Old 10-23-2010, 06:07 PM   #6
Mouf
My Ride: 2004 ZHP Sedan
and you have to figure in that your stock springs were sagging anyway, after 7 years of abuse they wouldn't be at the original height..
Mouf is offline   Reply With Quote
Old 10-23-2010, 06:21 PM   #7
EndlessAP1
My Ride: e92 M3, e70 X5, TL
Usually you don't see much with Eibach springs. I ran these 14 years ago in one of my Honda's and never ran them again. Over the years I ran the following suspensions on my cars:
KW Variant 3s
Aragosta
Top Secret
Spoon
Tein
Zeal
H&R
Bilstein
I have to say the best setup was the KWs. Zeals were pretty good too.
Acura TL
E92 M3
E70 X5
EndlessAP1 is offline   Reply With Quote
Old 10-24-2010, 07:31 PM   #8
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
i have the same set up, wait a couple of days for it to settle
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-24-2010, 08:45 PM   #9
surf2salsa
Thanks for the comments on both threads.
Old 10-25-2010, 05:03 AM   #10
Dreamliner330
My Ride: 330xi
I just got my koni and eibach set to he installed...curious...how does the comfort compare?
Sent from my PC36100 using BimmerApp
Dreamliner330 is offline   Reply With Quote
Old 10-25-2010, 12:36 PM   #11
xi_ter
My Ride: 2003 325xi
I have the same set up as the OP - Koni Sports and Eibach ProKit. I swapped out the 15mm upper rear spring pad and put in the 5 mm pads:
The end result:
Old 10-25-2010, 01:21 PM   #12
surf2salsa
I love the ride and handling, much better than the original stock setup.
Haven't messed with the front Koni adjustment yet.
I just think my height is a bit up there, I'll see in a couple of weeks how it settles.
Post pics as soon as you can.
Old 10-25-2010, 02:10 PM   #13
330Lover_
My Ride: 2001 330i bk/bk step
I have Eibach spring and stock sport shock. I have about half inch wheel gap in the front. GL.
01' 330i, step, bk/bk, moon, xenon, cd, 18x8 ASA AR1, 225/40/18 all around, Koni Yellow shock, Eibach Pro-spring, Axxis brake pads, 20mm rear spacers
330Lover_ is offline   Reply With Quote
Old 10-25-2010, 02:19 PM   #14
Kubica
My Ride: 2003 325xi
I think we should be brutal with the non-xi guys that come in our new house and track mud on the floor . . .
Old 10-25-2010, 02:28 PM   #15
fat-marshmellow
My Ride: ///M3 SMG
give it a couple days to settle, but if you wanted to go a little lower should've gone with the h&r setup...
heres mine with h&r sports, with the spring pads with 18" wheels
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
fat-marshmellow is offline   Reply With Quote
Old 10-25-2010, 04:18 PM   #16
surf2salsa
Thanks for the info, but sorry, the xi's are different.
Old 10-25-2010, 04:20 PM   #17
surf2salsa
Thanks for the pics.
The xi rides a lot higher. I can see with the H&R setup it's higher than the non xi's with H&R's that I've seen.
I went with the Eibach's because of the NYC/Jersey streets.
Anyone run H&R with the Koni's?
