E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
how can i separate outer balljoint from steering arm? (E46 Xi)
I was in the middle of replacing my control arms for my XI and kind of got stuck removing my control from where the outer ball joint connects to the steering arm. I tried banging it with a hammer and sticking a chisel in there and banging that with a hammer. No luck.
Please give me some more ideas, thanks guys.
![]() ** Too much for a sig - tim330i ** OMG LOOK AN E46! |
#2 |
Don't you need a specialized tool for that?
![]() ![]() Ballbusters Inc. DISCLAIMER: No balls were physically hurt during the reading of this post. Should redness and/or swelling occur consult your gynecologist immediately. |
#3 |
My Ride: 2000 328Ci 5sp SP
Use a tool called a "pickle fork" and a hammer.
#4 |
My Ride: 328Ci, 328iC, X3
You need one of these and a big hammer:
http://www.autozone.com/autozone/acc...rator/_/N-264r
Got Miles?
![]() 2000 328Ci Steptronic Original Engine & Transmission Original Transmission Fluid 15K Oil Changes So there! |
#5 | |
#6 |
Use a very heavy hammer and whack the crap out of it. It will come apart.
#7 |
Alright guys, after whacking a few times I noticed that my front strut is completely detached from the mount. did whacking it make that come off?
#8 |
um, wtf? You tore the upper strut tower attachment off? wow.
Ok, you will need a new Strut Tower now unless you can weld those bolts back on (not reccomended). Sry dude, should have read the instructions, you were supposed to keep everything bolted on while using the pickle fork. Start shopping for a whole new shock and strut. You are not removing that spring yourself, so you will need a whole new assembly. Maybe i can find you one cheap on ebay. brb. Note: Sometimes its a bad idea to get high before attempting something you have never done before. I have made similar mistakes myself.
![]() Last edited by Toad21; 07-15-2010 at 05:25 PM. |
#9 | |
thanks.
![]() ** Too much for a sig - tim330i ** OMG LOOK AN E46! Last edited by xecure; 07-15-2010 at 05:23 PM. |
#10 |
Ok I found a potential cheap fix.
http://cgi.ebay.com/ebaymotors/Used-...Q5fAccessories I am not at all sure how to attach this piece, we will need more expert help on this topic.
#11 |
Lowering has more negatives than positives, if you can find OEM parts you might be better off.
Ok you should buy a pair for the front Driverside $115 http://cgi.ebay.com/ebaymotors/Strut...Q5fAccessories Passenger Side http://cgi.ebay.com/ebaymotors/Strut...Q5fAccessories
#12 |
Just buy new OE mounts and be done with it. They were probably falling apart anyhow. What you want for the ball joints is a hinged separator.
#13 | |
Where can i get one of those tools?
#14 |
I replaced my control arms last week and had the same problem as you.. Hammered it for hours and it wouldn't budge.
Then I bought a pickle fork end for a pneumatic hammer and got it separated in less than a minute. Try it, It'll work. Last edited by maximepetit; 07-15-2010 at 07:55 PM. |
#15 |
Where did you buy it from? Would autozone have something like that?
#16 | |
It will come loose. 4 lb hammer, use both arms, follow through... Also, sometimes you don't even need a pickle fork. I don't recall how the XI looks under there. But a lot of the time you can just hit the spindle itself with the hammer (right where the ball joint goes through the spindle)
#17 |
Yeah that is no biggy, you just need the new mounts and rubber - do both sides while you are at it - nothing expensive, nothing crazy.
#18 | |
STOP BANGING YOUR CAR!!!! IF YOU ALREADY TRIED BANGING YOUR CAR FOR MORE THAN 5 TIMES AND STILL NOT LOOSE, FORGET IT. TRUST ME, JUST BUY A BALL JOINT SEPARATOR FROM NAPA STORE, SEARS, EBAY. AUTO ZONE DOESNT EVEN KNOW THIS TOOL EXCEPT FOR THE PICKLE FORK. YOU CAN TRY KRAGEN.
#19 | |
If all you've done was tore the strut out of its rubber, then, yes you should only need a new strut mount (but, as mentioned, you might as well do them in pairs). |
#20 |
Looks like Harbor Fright has a similar tool on sale now:
http://www.harborfreight.com/3-4-qua...tor-99849.html Discussion of said tool: http://www.m5board.com/vbulletin/e39...separator.html |
