E46 Xi Forum
Old 10-27-2010, 01:14 PM   #1
Esmir93
My Ride: 2004 BMW 300XI
DSC problem ;(
I have a friend who fixes cars that were in salvage state so I decided to get a car from him, he did everything great but there was a problem neither he or I could fix, the DSC won't work and therefore the brake,abs,the little circle next to the abs sign and in the middle the triangle with the circle around it all light up when I turn the car on. Now, the car is fine, everything else works perfectly except this but I'd just like to see if anyone could help me out or give advice how to fix it.
Btw, it's a 2004 BMW 330xi
Esmir93 is offline   Reply With Quote
Old 10-27-2010, 02:50 PM   #2
Kubica
My Ride: 2003 325xi
Drive the car for 5 miles and see if it goes off. I get those lights often when i've had the battery disconnected.
Otherwise scan the codes- probably a wheel speed sensor issue if i had to guess.
Old 10-27-2010, 03:04 PM   #3
335iTah
My Ride: 335i>330i
wheel speed sensor
Originally Posted by RAFF112 View Post
Calm down, gently remove your tampon and then sit back relax and enjoy a nice glass of 'mind your own fuccing business'.
335iTah is offline   Reply With Quote
Old 10-27-2010, 04:39 PM   #4
Esmir93
It's been like this always though, ever since the car came in and it never turned off. Nor does the DSC button do anything.
Are you sure its the wheel speed sensor?
Old 10-27-2010, 07:16 PM   #5
xi_ter
My Ride: 2003 325xi
You can get the DSC codes read to be sure. It will cost $125 to get codes read, but the DSC module reads which wheel sensor is faulty. In my case, my rear passenger sensor was scrapped by a rock caught in the hub.
Old 10-27-2010, 07:27 PM   #6
Esmir93
is it hard to change the sensor? and how could I get the codes read
Old 10-27-2010, 07:53 PM   #7
xi_ter
My Ride: 2003 325xi
Phone around for best price - reader needs to read the DSC codes. The sensor is held by one hex bolt and connected electrically by an end harness that tucked in a box under the car.
Old 10-27-2010, 07:57 PM   #8
Esmir93
okay thank you I'll see what I can do
Old 10-27-2010, 08:21 PM   #9
Bulit7
My Ride: 328Ci
good info!!
Bulit7 is offline   Reply With Quote
