E46 Xi Forum
Old 10-27-2010, 05:49 PM   #1
tuan_xi
My Ride: 04 325xi
xi nasty vibration on the highway
hey guys! my 2004 325xi
-lowered on H&Rs
-Auto
-120,000 km on the clock
-i have 17x8 tsw nurburgrings 35offset squared, wrapped in potenza re760 sports
- 3 months ago i replaced the passenger front cv shaft
-last week i replaced the drive side cv and lower control arm.
i take the same route home everyday, going the same speed all the way home, lately from 90-100 im getting a wicked vibration felt through the gas pedal, the seat and steering wheel. ( i work at a service center) today i got the car up in the air, took the wheels off...inspected, balanced and rotated them. still the problem persist. has anyone had this problem before?
TOPAZBLUE AWD E46
tuan_xi is offline   Reply With Quote
Old 10-27-2010, 10:31 PM   #2
Gottalovethexi
Gottalovethexi's Avatar
My Ride: 03 xi & 72 Bav
i had to get my front right half shaft replaced when i had serious wheel shake at 50-60mph
Old 10-28-2010, 01:04 AM   #3
navairum
My Ride: '04 325XI
Mine did this when the cv boot was blown. Also could be an axel thing
navairum is offline   Reply With Quote
Old 10-28-2010, 07:23 PM   #4
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
ive got the same issue. have you changed the diff/transfer case fluids? it could be the axles. What brand did go with.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-28-2010, 07:28 PM   #5
TiAgXi
My Ride: e46xi, e46m
Generally speaking, bad cv joints will tend to cause more vibration under hard acceleration. Is that one of your symptoms?
Also, with regard to the control arms, it's a good idea to replace them in sets. With suspension parts in general, if you replace a part on one side, you should replace the same part on the other side.
A number of things can cause a vibration, so it can be hard to diagnose. I had a vibration and it turned out to be a worn bearing pedestal.
TiAgXi is offline   Reply With Quote
Old 10-28-2010, 11:11 PM   #6
Birdman203
My Ride: 2002 325xi
I had a vibration and it turned out to be the transfer case Gotta look very close when dealing with vibrations.
Birdman203 is offline   Reply With Quote
Old 10-29-2010, 01:44 AM   #7
fat-marshmellow
My Ride: ///M3 SMG
the more i try to fix my xi the more i get more frustrated with it....out of topic but just saying because i have the same problem too
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
fat-marshmellow is offline   Reply With Quote
Old 10-29-2010, 10:47 AM   #8
Ivanhoe
My Ride: BMW 330 xi 2005
Why do you try with a front alignment ?
Ivanhoe is offline   Reply With Quote
Old 11-04-2010, 05:43 PM   #9
camachu
My Ride: 02 325XI
vibrations in the middle of the car
i have a 2002 325xi and i think i have the same issue, bmw tech said it was the front drive shaft , he lifted the car and the shaft had a lot of play.
i can also feel it when im driving . for example im on the highway i let the gas pedal go , and i press the brake and then step on the gas again to resume speed and i can hear a clunck noise and vibrations in the middle of car. im replacing my front drive shaft next weel . i will post results then.
camachu is offline   Reply With Quote
Old 11-04-2010, 11:11 PM   #10
M5chaser
My Ride: E46 330xi, E39 M5
My bet is that your wheel is bent.
This happened to me - despite balancing all wheels I had vibration only at a certain speed.
You may want to have someone inspect the wheels while being rotated to see if they are perfectly straight.
Good luck.
E46 330xi///M5 CHASER
M5chaser is offline   Reply With Quote
Old 11-05-2010, 06:54 PM   #11
q0192837465
My Ride: 99.4 A4, 03 330xi
Send a message via ICQ to q0192837465
Thumbs down
Good luck.
Agreed. I have the exact same thing and it turns out 3 out of 4 wheels are bent. It only happens when the front wheels are bent. You won't feel much if you back wheels are bent. Another thing to notice is if a wheel uses an unusal amount of weight to balance, it's an indication that it's bent.
Good Luck
Edit: Didnt meant for the thumbs down to be there. Oh well.
q0192837465 is offline   Reply With Quote
Old 12-04-2010, 12:08 AM   #12
shadow 2
My Ride: 07 328i
Did you have to replace the drive shaft or just repack grease in the boots? If shafts, mind saying what you paid? Think one or more of my front shafts is going bad and I will need to pay my Indy to replace. bTW, still waiting for your results from your shaft replacement.
shadow 2 is offline   Reply With Quote
Old 12-04-2010, 12:33 AM   #13
TwoDuckDad
My Ride: 2001 330xi jet black
Did you perform a road force balance? A regular spin balance is not nearly as accurate. The road force balance will indicate to the operator the best position of the tire on the wheel. In other words the machine will show the correct position of the tire on the wheel by showing the operator where to mark each then break the bead and take the tire partially off so it can be rotated to the correct position on the wheel. This allows you to have the best alignment between the imperfections of the wheel and the tire.
While many tire shops offer this service you need to make sure the operator knows his stuff or he can screw it up. FYI - I'm told that all BMW dealers are required to have the road force balancing equipment.
Hope you find the problem - I've been there and it sure takes away from enjoying your ultimate driving machine.
Premium, Sport, & Cold Weather Packages
If you dog doesn't like somebody maybe you shouldn't either.
TwoDuckDad is offline   Reply With Quote
Old 12-05-2010, 01:55 PM   #14
shadow 2
My Ride: 07 328i
Taking my car in for cv service this week. May need a drive shaft or hopefully just a new boot. Any exp regarding what price to expect from an Indy for this work?
Old 12-05-2010, 02:16 PM   #15
athayer187
My Ride: 2004 330xi
Double check the control arm bushings too - I had a similar vibration when a set of Powerflexes I had started to come apart.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 12-05-2010, 02:59 PM   #16
shadow 2
My Ride: 07 328i
My car just gets a vibration when I floor it. Otherwise, it seems ok. CABs give that symptom too?
Old 12-05-2010, 06:52 PM   #17
athayer187
My Ride: 2004 330xi
Yeah, that's what mine was too - it's when you're unloading the front end but still sending torque. It's worth the 15 minutes to check them out.
Old 12-05-2010, 09:11 PM   #18
shadow 2
My Ride: 07 328i
I plan to get it checked either Tuesday or Wednesday so will see what happens.
Old 12-07-2010, 02:06 AM   #19
cardsfan007
My Ride: 2002 330xi
i am having the vibration problem right around 55mph, i think its just a wheel out of balance, or at least im praying its only that. ive also been told that it may just be because we have a certain kind of strut that does that, because the vibration goes away if i go over 60 or under 50. any ideas?
cardsfan007 is offline   Reply With Quote
Old 12-07-2010, 07:46 AM   #20
shadow 2
My Ride: 07 328i
Had same issue last year, was a slightly bent front wheel.
