E46 Xi Forum
Old 12-13-2010, 12:07 PM   #1
bmwstephen
My Ride: e46 325XI, e36 M3
I and XI wheels interchangable?
Hi all,
I'm trying to revert my car to stock. I found some stock wheels that came from an I (RWD) but was wondering if these are interchangeable with XI? I heard that the XI had a slightly different offset for their spoke 45s.
bmwstephen is offline   Reply With Quote
Old 12-13-2010, 12:46 PM   #2
Kubica
My Ride: 2003 325xi
They should be fine, but don't put a staggered set on. M3 wheels wont work either.
Old 12-13-2010, 12:50 PM   #3
Gottalovethexi
Gottalovethexi's Avatar
My Ride: 03 xi & 72 Bav
offset shouldn't matter, it's whether the set is staggered or not (risk of variation in rolling diameters)
Old 12-14-2010, 09:27 AM   #4
Ivanhoe
My Ride: BMW 330 xi 2005
Originally Posted by kaboo0m View Post
Hi all,
Check this :
http://forum.e46fanatics.com/showthr...043&highlight=
They came from a 330 xi 2005
Ivanhoe is offline   Reply With Quote
Old 12-14-2010, 12:06 PM   #5
feddomw
My Ride: 325xi Touring
For the record, my (German) instruction manual that came with my 325xi (I live in the Netherlands) does have the wheel specs and staggered is "allowed" by BMW.
I would never go with staggered due to bad experiences on a previous (non-M) e36.
feddomw is offline   Reply With Quote
Old 12-14-2010, 12:13 PM   #6
SamDoe1
My Ride: 4cyl of fury
The staggered doesn't matter as long as you are SURE that the overall wheel diameter (rim and tire included) is exactly the same. The biggest downside to staggered is that it will increase your understeer which the xi already has enough of. Stick with square, your smile will thank you.
Old 12-14-2010, 06:58 PM   #7
exeye325
My Ride: 2004 325xi
I bought a set of rims from a Z3.
exeye325 is offline   Reply With Quote
Old 12-15-2010, 11:34 PM   #8
mujjuman
My Ride: not an E46
agree i would stick with the same size all around
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 12-16-2010, 12:13 PM   #9
bmwstephen
I just want to stick to the stock 16inch spoke 45's but I recall back in 04 when my cousin bought a regular RWD version, his spoke 45's were slightly smaller than mine but I think this thread just confirmed that I misinterpreted everything. Thanks!
Old 12-16-2010, 06:44 PM   #10
kem
My Ride: E46 330xi
Running mildly staggered setups should be just fine if you keep a square tire setup. I'll let everyone know once I get some road time on my new winter setup, I got some e90 sport wheels, 18x8 in front and 18x8.5 in the back but they have offsets in the mid 30's to make a more aggressive stance similar to my BBS CH's.
One tire will be slightly stretched compared to the other so the diameters won't be identical, but I believe the difference will be so small it shouldn't affect anything. I know when I had a tire disintegrate on a set that was about 50% worn, I only replaced the tires on the front which would affect the overall diameters too and I noticed no ill effects.
kem is offline   Reply With Quote
Old 12-23-2010, 11:28 AM   #11
loeppd1
My Ride: 2004 325xi
True - staggered set up works fine on an xi so long as the rolling circumference is the same. Its just as essential for ABS not only the all wheel and DSC. Suggested (optional) set up (direct from BMW for XI in Canada) is 225/40/18 front and 255/35/18 back. I run these on 8s in the front and 8.5s in the back with 47 and 50 offsets respectively. I'm and everyday driver, don't track my car but like the staggered look so for me its mostly estetics. Downside of course is it limits your ability to rotate tires. That said I run winters on stock 16s with a square set up for 5-6 months of the year and summers on my 18s for the balance so my rubber is going to last longer than if I was running an all season on the 18s year round. Check out this link the difference between these is 2 revolutions per mile or 0.2% difference. The difference is so marginal, it would never impact the AWD system negatively. Arguably, uneven wear on your tires could be greater than this. That said, BMW probably is the most forgiving in this require, Subarau and Audi are much more finiky. At some point I may swap out my fronts for another pair of 8.5s and put 255s all around but for now I'm happy.
http://www.miata.net/garage/tirecalc.html
loeppd1 is offline   Reply With Quote
Old 12-23-2010, 09:25 PM   #12
SLVRXI
My Ride: 2001 325xi
I want to put a staggered set of wheels on an, have been looking around at what everyone has said that there running, on their XI. I still don't understand why some choose to run a 40 series on the front and a 35 on the rear? why not a 35 or 40 series all the way around? By having to different side wall sizes create a different wheel rotation?
Example 225/35/19 Front on 19x8
225/35/19 Rear 19x8.5 (slight stretch)
I've read some one runs- Front 19x8.5 225/40/19
Rear 19x9.5 225/35/19
SLVRXI is offline   Reply With Quote
Old 12-23-2010, 09:51 PM   #13
loeppd1
My Ride: 2004 325xi
Its all about rolling diameter. If you run all the same widths say 4 x 225 then the profile/sidewall should all be the same 35s all around or 40s all around but if you have different widths 225 front and 255 back you need to run a different profile/sidewall in the back. The profile/sidwall is 40% of the width so 40 on 225 is like 35 on 255. It is absolutely essential that the rolling diameter is exactly the same otherwise you will mess up your all wheel drive and will cause your DSC and ABS not to work. I'm sure you have the last bit of your post wrong, I doubt anyone would willingly run Front 19x8.5 225/40/19 Rear 19x9.5 225/35/19. Are you sure that the back wasn't a 255 because that would make more sense
Old 12-23-2010, 10:47 PM   #14
SLVRXI
My Ride: 2001 325xi
It may have been a 255. I know he had M3 wheels on, I don't remember where i seen it on the forums tho. I want a set of LM reps but with a lip on rear if possible? an don't fully understand how to choose the proper offset. An i have used the search button. Just would like a good answer for fitment, with or with out spacers.I want this look for wheel set up http://forum.E46Fanatics.com/attachm...1&d=1293165930
Old 12-24-2010, 05:54 AM   #15
shadow 2
My Ride: 07 328i
I run 225 x 45 front and 245 x 40 rear on 17 inch staggered wheels. I understand this was an optional wheel/tire setup with staggered Style 68 wheels in Canada when our cars were new.
shadow 2 is offline   Reply With Quote
Old 12-24-2010, 12:31 PM   #16
dephantn
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
I have exactly Shadow2 in Canada.325Xi-2002, very good ,only in dry warm time, Winter go back to 205-55R16 winter tires.
Really good, smiling when see other car stuck on heavy snow or icy. Now my son drives Xi.
And the same with X5 couple years ( X5 pre 2005 is exactly AWD of E46 XI).
dephantn is offline   Reply With Quote
Old 12-24-2010, 03:59 PM   #17
loeppd1
My Ride: 2004 325xi
Very satisfying when you pull away on a green light as if you were on dry pavement whilst others sit and spin through the intersection! I go back to 205/55/16 for the winter and its like driving a 4x4 truck except better because the xi has a low centre of gravity..........truly the best of both worlds!
