Old 11-13-2010, 02:23 AM   #1
joez323i
My Ride: 323i
Brown Wire on Valve cover?
I tried to change my valve gasket today. I broke the brown wire located in the middle. When I tried to take off the wire connection, the top nut stick with the bottom nut together. So when I turn the top nut, instead just the top, the whole thing is turning. I tried to hold the bottom with open wrench while turning the top nut counter clockwise to separate them and still it won't move. So I ended to turn the whole thing, twisted the cable and it's broken now. I'm just wondering what cable is this? Can I fix it by soldering the wire to the metal connector (it split just at the end of the connector, no cable sticking out from the metal ring connector)?
The second I finally open the gasket, rain just pouring really hard in an instant for 5 minutes and it just stop. Hopefully it didn't get inside it. As it's getting dark, I went to buy a a new night light so I can continue working. Just after I turn the light on, the rain start pouring really hard again. And just like before, hopefully the rain didn't get inside the engine. Sigh... It's been a shitty day for me. Hopefully someone can help me with the cable.
Thanks.
joez323i is offline   Reply With Quote
Old 11-13-2010, 02:46 AM   #2
dmak_el
My Ride: 330
its a ground for ign. coil i believe. u should fix it.
dmak_el is offline   Reply With Quote
Old 11-13-2010, 04:01 AM   #3
cityjohn
My Ride: 2001 M3
Whenever you see a brown wire on a BMW it's a ground.
cityjohn is offline   Reply With Quote
Old 11-13-2010, 04:02 AM   #4
paraklas
My Ride: ESS TS2 320ci
1st.. yes, you should repair the ground cable because you will get all sorts of issues, mainly misfiring. 2nd, from what I understand, it was raining while your valve cover was off? If water got into the engine, I'd do an oil change as well
Old 11-13-2010, 08:31 AM   #5
RogueStatus37
My Ride: '04 330ci
Repair it immediately. Its the ground and if you try and run the car, you will misfire, but the car isnt sensitive enough to pick up a loose ground so youll be searching for years to figure out why it misfires if you forget about it.
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
