Old 10-30-2010, 12:48 PM   #1
paraklas
My Ride: ESS TS2 320ci
Using "Normal" sockets with Impact Wrench
I recently acquired a heavy duty electric impact wrench, for loosening the stubborn nuts and bolts (torque wrench always for tightening) and I was wondering - given the fact that we are working on a BMW, and not erecting steel beams on a building - is it mandatory to get impact wrench compatible sockets? From what I understand, impact wrench sockets are stronger than the normal ones which may break.
Mine already came with 17, 19, 21 and 22mm sockets but if I remember well, suspension, braking and other components are 16mm and below.
Old 10-30-2010, 02:25 PM   #2
slammin_330
My Ride: is no ZHP.
I use regular sockets on my impact gun when the impact sockets are too thick. I also use Snap-on and Craftsman sockets, so if I do snap one, I'll just get a free replacement.
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
Old 10-30-2010, 03:38 PM   #3
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Never use chrome plated sockets in an impact gun. They are made differently from the impact sockets and and could break under the torque of the impact wrench.
-Gary
DiscoStu is offline   Reply With Quote
Old 10-30-2010, 04:45 PM   #4
beamin87
My Ride: 2002 BMW 325ci
yea def a big no no on pneumatic impacts...electric ones are a little more forgiving. my snap on one has yet to break one or round the teeth inside the socket but im sure it will happen eventually...for those stubborn bolts i would recommend using hand tools to break them loose and remove them as an electric one wont break them loose. i love my electric one for removing fender bolts valve cover bolts, and any bolts that there are alot of...it doesnt have enough torque to break really stubborn ones loose. the guys here at the shop use makita li ion elec impacts for the same thing.
beamin87 is offline   Reply With Quote
Old 10-30-2010, 05:02 PM   #5
gdr888
My Ride: LSB M3 E46
I've been using "normal socket" on my cars for the past 3 years and haven't had any issues with it.
04 JPB STi
02 LSB M3
gdr888 is offline   Reply With Quote
Old 10-30-2010, 05:31 PM   #6
mcurcio1989
My Ride: 2002 325xi
I use regular sockets all the time. I have broken some. It is not going to hurt anything aside from your socket.
mcurcio1989 is offline   Reply With Quote
Old 10-31-2010, 06:06 AM   #7
paraklas
Thanks for the feedback! The impact wrench is a 220v model with 450Nm of torque so I guess it could snap a socket, although most of the impact wrench accessible nuts/bolts on a BMW shouldn't be torqued THAT much. Will get the bigger sockets and the joints for now.
Old 10-31-2010, 08:51 AM   #8
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
not mandatory but if you want to get the most torque possible, you'll need impact sockets to withstand the abuse. Otherwise, you'll keep cracking regular sockets.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-02-2010, 02:18 PM   #9
havnfun328
My Ride: '99 328i, '03 M5
One think to be careful of is whether they are 12pt or 6pt sockets. Impact sockets are always 6pt. There is a bigger risk of rounding over heads with 12pt.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 11-02-2010, 03:02 PM   #10
Spartan E46
My Ride: 2000 323i
Regular sockets are not designed to take the shock that impact wrenches apply - when using them in this way there is a chance that a socket could break and that pieces could end up flying into an eye - or elsewhere. However small or large that chance is sounds like a debate that I am not prepared to have.
If you decide to use a standard socket with an impact wrench - use caution. It makes protecting yourself that much more important. then again, safety glasses and heavy work gloves should be standard fare with an impact wrench regardless of what type of socket is at the end of it.
Spartan E46 is offline   Reply With Quote
Old 11-02-2010, 06:21 PM   #11
bigjae1976
bigjae1976's Avatar
If you are using a relatively low power 3/8" air wratchet...you'll be OK. If you are using a 3/4" impact gun on "blow your mind" mode with 2 reducers and a regular 3/8" socket on the end...not a good idea.
In the long run, you'll save money using impact sockets if you frequently use air tools by not having to replace cracked sockets.
Old 11-03-2010, 01:05 AM   #12
paraklas
This is the one I have:
Link here
Guess for its power rating I should get the proper sockets
Old 11-06-2010, 06:21 AM   #13
mystert
My Ride: 2003 330Ci
Has any DIYer (not professional mechanic) on this site actually broken a 1/2" drive regular socket with an impact gun? or is this just another read and regurgitate situation that is so common in car forums.
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 11-06-2010, 07:17 AM   #14
bigjae1976
bigjae1976's Avatar
I broke an 8mm deep socket on my 3/8" air wratchet.
Old 11-06-2010, 04:44 PM   #15
erfont
My Ride: 02 325ci
My uncles right hand is basically crippled from having it wrapped around a chrome socket when it exploded. Shrapnel ripped most of the tendons in his hand. I will not use anything but impact 3/8 and above. Pneumatic or electric. It's not worth it.
erfont is offline   Reply With Quote
Old 11-08-2010, 11:06 AM   #16
jgold47
My Ride: 2004 X5 3.0
I have broke 1/2" drive sockets using a hand op torque wrech. I would get a good set of CRV sockets.
that torque wrench is a monster. I am not sure I have come across a 110v one that can get 450NM (330ftlb). Must be a 220 thing.....
I lied
http://www.northerntool.com/shop/too...&ci_sku=399570
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
