Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-30-2010, 10:43 PM   #1
TrippinBimmer
My Ride: ZHP Custom Stage 3.5
Brembo BBK Rotors Replacements
I know a Few of You Guys are running BBK. I was doing some research and say that Brembo Replacement Rotors are like $500-600 per ring. Then, I saw Stoptech Aero Rotor Rings are that Decently Priced at $200-250 Per Ring. Finally, I saw RaceingBrake have only the 355mmx32mm for $195 Per Ring.
Any Tips Guys? I really dont want to Spend 2 Grand on 4 rotors. I know Stoptech are Great Rotors but I know they are softer then Brembo's. I won't be tracking so that isnt an issue. What I am really asking is it really worth it?
Also, Stoptech Aero Rotor Ring 345mmx28mm the same as the Brembo's? Cause no one said it's compatable...
Alot of People Told me NOT to go RacingBrake as they have issues with them and etc...
-TrippinBimmer
Old 10-30-2010, 11:42 PM   #2
ryanwhite74115
My Ride: 2011 Hyundai Sonata
A reason I never have and probably won't ever go BBK...ever: replacement parts almost cost as much as an entire new setup. GL
(\ /) or \(`–' )/
c('')('')
ryanwhite74115 is online now   Reply With Quote
Old 11-01-2010, 04:46 PM   #3
ModBargains
ModBargains's Avatar
My Ride: E30 325e & E46 ZHP
I couldnt tell you if they were compatible, but I do know that StopTech is definitely a quality product.
Kevin
ELLIOTT GOODMAN
Elliott@ModBargains.com | (714) 582-3330 ext. 8009
Hours: Monday - Friday 8:00am-7:00pm | Saturday 8:00am-5:00pm (PST)
Authorized Dealer of: Forgestar Wheels l KW Coilovers l D-Force Wheels l BMW E46 Parts l BMW Angel Eyes |BMW Accessories
ModBargains is offline   Reply With Quote
Old 11-02-2010, 05:58 AM   #4
bigjae1976
bigjae1976's Avatar
My Ride: A car
If the attachment points are the same...don't see a reason why a brembo and ST ring couldn't be interchanged.
This is the reason why I went with my UUC/Wilwood kit...parts are a lot cheaper since it uses the OEM M3 rotor and a fairly common pad...as long as you stick with the 4pot calipers. 6 pot? Pad selection is a whole different story.
But, I think the Brembo and ST stuff will last a lot longer than OEM parts since they are bigger and thicker, can dissipate more heat faster, and made to handle more heat. While replacement parts are expensive, I think you get a lot more mileage/track time out of them. Not saying the a BBK is always cheaper in the long run...
bigjae1976 is online now   Reply With Quote
Old 11-02-2010, 10:35 PM   #5
SC_TR0JAN_M3
My Ride: 2004 BMW M3
looks like you took the leap without looking... i'd stick with the brembo branded rings
2004 CB 6 Speed ///M3
Looking For :: GC Race Sways :: SS Race ::
SC_TR0JAN_M3 is offline   Reply With Quote
Old 11-03-2010, 12:27 AM   #6
TrippinBimmer
I have been doing research, before I leap and bought the BBK. For the Price I paid its not a bad deal at all
For anyone who wants to know if the Stoptech 345mmx28mm will fit on the Brembo Rear. There is currently no StopTech 345x28mm rear rotor/hat combination for this Brembo kit. In fact, the StopTech 345x28mm AeroRotors do not mate with the Brembo hats for this kit, since the StopTech rotor mounting flanges are beefier and interfere with the Brembo hat centering ring.
My rear is not Brembo so it will fit just fine. but they are replica of the Brembo with less tighter specs.
-TrippinBimmer
Old 11-03-2010, 12:56 AM   #7
bigjae1976
bigjae1976's Avatar
My Ride: A car
OT...what do you have on the rear? ST does not have a rear kit.
Old 11-03-2010, 02:00 PM   #8
TrippinBimmer
ST do carry a rear kit but its a Special Order Item. Reason for this. ST believe that the 330i doesn't need a rear kit as the stock one will do just fine.
My Rears are F Carbon BBK. It's from a Company that went out of business 3 years ago. Replacement parts is kinda hard to find but you just gotta know where to look.
-TrippinBimmer
Old 11-03-2010, 02:15 PM   #9
kent330i
kent330i's Avatar
My Ride: 2005 330i ZHP
Send a message via AIM to kent330i
For the StopTech 345mmx28mm rotor ring to fit on a brembo hat, you will have to modify the brembo hat (machine off the lip at the bottom) to make it fit. The stopTech 355mmx32mm rotor ring fit perfect with the brembo front hat.
kent330i is offline   Reply With Quote
Old 11-03-2010, 02:16 PM   #10
mkodama
mkodama's Avatar
...And now you can feel the pain of all Porsche owners.
Old 11-03-2010, 02:20 PM   #11
TrippinBimmer
This is Correct but Race Technology will blow up this thread about not modifying there hats and its dangerous.
-TrippinBimmer
Old 11-04-2010, 05:04 AM   #12
bigjae1976
bigjae1976's Avatar
My Ride: A car
Really? I did not know that.
Old 11-04-2010, 02:59 PM   #13
TrippinBimmer
Yep,
-TrippinBimmer
Old 11-04-2010, 03:02 PM   #14
mvrk10256
My Ride: E30 325i
was there a thread with pictures or are they still unmouted? i wanna see how they look on the car.
Old 11-04-2010, 03:31 PM   #15
bigjae1976
bigjae1976's Avatar
My Ride: A car
Yep,
-TrippinBimmer
Do you have any details? Is it with the ST40 caliper? And do you know what the rotor size is?
Old 11-04-2010, 03:51 PM   #16
TrippinBimmer
There is a thread with update on the recoating progress and I will do a proper photoshoot when all is done
..::|TrippinBimmer and Tirado Custom Coatings : Stripping and Powercoating BBK|::..
If I recall correctly when I inquire about them it was 345x28mm with ST-40 Caliper. E-brake is still there I would call ST to verify. It has been awhile since I called them.
-TrippinBimmer
Old 11-04-2010, 04:46 PM   #17
bigjae1976
bigjae1976's Avatar
My Ride: A car
-TrippinBimmer
Thanks You're an OK guy sometimes!
I like the blue calipers!
