Old 11-02-2010, 12:09 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
eas | Plug and Play Lightweight Batteries for your E46 M3!
Gentlemen,
If you've ever taken out your stock battery for whatever reason, you'll know why this is an issue of concern. The stock battery that's in your car right now, is extremely heavy, and that added weight isn't great for your performance.
If you want a battery that is lighter than stock, but still gives you the performance you need during cold weather, then you should consider the following plug and play battery's that don't require any adapters whatsoever to your BMW:
BMW - Lightweight Battery (55Ah 480CCA) - 36lb.
http://www.europeanautosource.com/pr...oducts_id=2427
Power rating is at 55Ah 480CCA, weighing in at 36lbs. Approximately 30lbs lighter than stock.
BMW - Lightweight Battery (70Ah 760CCA) - 45lb.
http://www.europeanautosource.com/pr...oducts_id=2426
Power rating is at 70Ah 760CCA, weighing in at 45lbs. Approximately 20lbs lighter than stock.
If you have any questions in regards to the batteries, please feel free to ask!
david @ eas is offline   Reply With Quote
Old 11-11-2010, 04:10 PM   #2
02silv///M
My Ride: 02 Silver ///M
yup guys!!! it's lightweight alright. that only thing i see heavy is the price...
02silv///M is offline   Reply With Quote
