Old 11-02-2010, 10:17 PM   #1
TrickTizzle
My Ride: 325i
O2 Sensor issue after headers
This problem has been going on for about the last 2-3 weeks. I have ceramic coated headers with o2 sims that I bought from Anthony at Bimmerbrakes...
So here is what happened.
2 Weeks ago, I got a SES light, pulled codes and got
O2 SENSOR HEATER CIRCUIT VOLTAGE TOO LOW
I reset the code, but it came back at next start up. Then couple days later I got
SECONDARY AIR INJECTION SYSTEM INSUFFICENT AIR
I reset that code aswell, and came back at next cold start when the secondary air pump tried to run. So then I got under the hood, and made sure my o2 sensor connections were secure, but I disconnected my heater wire and reconnected it any how. My secondary air pump valve had a busted off vaccumm line so that would explain that code.
After reconnecting wires, they did not come back for 3 days, then SES came back on, and this time it told me
O2 SENSOR HEATER CIRCUIT VOLTAGE TOO HIGH
so I reset it, and the next day I got
O2 SENSOR HEATER CIRCUIT VOLTAGE MALFUNCTION
...and I still have that code, so WTF is going on? Any one every had this issue? Also I purchased new o2 sensors when I setup my sims...
Old 11-03-2010, 12:20 AM   #2
TrippinBimmer
My Ride: Just Fast!
I would check your voltage that is going back to the DME on the Heater Side. Also, forgot to tell everyone that incorrectly install the sims. Connecting the Sims to the Heater Wire instead of Signal wire of the o2. You Maybe have Damage the DME. I'm not 100% sure without a reading and testing from a GT1.
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-03-2010, 12:34 AM   #3
Steven747
My Ride: 05 330ci
interesting issue i hope you figure it out.
Old 11-03-2010, 07:15 AM   #4
TrickTizzle
My Ride: 325i
I'm pretty sure DME isn't damaged because the setup worked flawless for 2 to 3 weeks without any service engine soon light.
-TrippinBimmer
Sent from my MB200 using BimmerApp
Old 11-03-2010, 09:55 PM   #5
TrickTizzle
My Ride: 325i
bump...no one has a clue?
Old 11-05-2010, 03:32 PM   #6
TrickTizzle
My Ride: 325i
anyone?
Old 11-08-2010, 08:19 AM   #7
TrickTizzle
My Ride: 325i
Bump
Old 11-08-2010, 12:45 PM   #8
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
I have the same problem with Anthony's O2 sims and so have others. Try different sims maybe?
phamine is offline   Reply With Quote
Old 11-08-2010, 12:47 PM   #9
TrippinBimmer
My Ride: Just Fast!
Sim has nothing to do with the Heater part of the o2. Mine is running just fine...
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
Stock
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-08-2010, 02:31 PM   #10
TrickTizzle
My Ride: 325i
-TrippinBimmer
How do you check resistance from voltage meter?
Old 11-08-2010, 11:05 PM   #11
mvrk10256
My Ride: E30 325i
you set the voltmeter to the symbol Ω then you will measure resistance.
Here are a couple of things. the heater circuit is stock. Make sure that you that the white wires are connected to each other. The polarity doesnt matter, just make sure the white wires are connected. they have NOTHING to do with the sim. absolutly nothing to do with each other.
So once you make sure they are connected properly make sure that you wire the sim the way anthony tells you to. If you have any questions feel free to pm me as well. Taking pictures will also help. measure the voltage coming from the sim is between .3 and .5V.
Also in my opinion Anthony's sims work and o2sims.com sims dont work. the only other option would be to buy an adjustable one and fine tune it.
Old 11-08-2010, 11:22 PM   #12
TrickTizzle
My Ride: 325i
Right now I have a heater circuit issue, and when I measured the resistance it was 2.6 with the ignition on, once the car turned on it went all out of whack, etc.
I had another o2 sensor laying around and I just hooked it up with the harness/o2 sim. I think I should get only one code for o2 heater circuit malfunction versus getting two.
Old 11-08-2010, 11:32 PM   #13
mvrk10256
My Ride: E30 325i
you can get 2 codes for the o2 heater circuit.
However you got 2.6 what? 2.6 ohms? or 2.6Kohms?2.6Mohms?
cause that makes a big difference. It is pretty difficult to mess that up since it just a resistor and two wires. the resistance across that wire should not change just cause the car is on so I think you are measuring the wrong thing....
Old 11-10-2010, 08:28 PM   #14
TrickTizzle
My Ride: 325i
2.4ohms.
I think the o2 sensor heater circuit is on crack because I replaced one o2 sensor and hooked it up with the sims, and now I only get 1 code for my o2 sensor heater circuit.
What happened was that when I initially installed the o2 sensors I thought the white wires were the signal wires, so I cut those and had to re splice them. It ran fine for a month, but then I started to have problems and stuff.
Old 11-13-2010, 08:46 PM   #15
dpgrand
My Ride: 2005 330xi
I had o2 sims installed, but got similar codes to you. I have since installed an Innovate LC-1 (there is a thread on here detailing the procedure), but that still hasn't solved my SES light. I'm convinced the only solution is software removing the post-cat 02 sensors.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 11-14-2010, 12:44 AM   #16
TrickTizzle
My Ride: 325i
The software wont fix my issue. I have a heater circuit issue, and even if you get a tune the car will still look for the circuit. On the plus side I'm not getting emissions codes so the circuit issue is a easy fix.
Old 11-14-2010, 12:54 AM   #17
mvrk10256
My Ride: E30 325i
I would suggest you speak to Anthony personally about the heater issue again. I know he runs heater circuit sims as well on his car. maybe he can hook you up so you dont need to buy new o2 sensors.
Old 11-14-2010, 08:17 PM   #18
JB_ZHP
My Ride: 05' ZHP Dinan 3
I have the o2sims.com product installed with no problems for 1 year now.
e46 signature
JB_ZHP is offline   Reply With Quote
check engine, circuit, dme, o2 sensor, voltage
