Sponsored by BimmerWorld
Old 11-03-2010, 06:57 PM   #1
5ynd1cat3
My Ride: pisses off liberals
Cup Kit...wrong compressor?
Hey all,
I started the arduous task of my strut installation today and I have an issue I've never run into before. I have the spring compressed on the highest/lowest coils available without interfering with the top assembly or lower perch, but I can't seem to be able to compress the spring enough to bolt everything up. Also, if I line the spring up with the bottom of the perch (similar to the OE setup where the last coil ends at the stop on the perch) then the strut goes through the spring diagonally. If I line it all up so the strut goes up the middle, then the last coil stops short of the stop on the perch. I searched and searched but all the threads regarding this problem die off with no resolution. Anyone have any advice?
5ynd1cat3 is offline   Reply With Quote
Old 11-03-2010, 07:26 PM   #2
Bake
My Ride: AW F10 535 M-Sport
I just responded to your other thread. Hope they can help.
Sent from my iPhone using BimmerApp
Bake is offline   Reply With Quote
Old 11-03-2010, 08:06 PM   #3
Minnoe07
My Ride: 2004 BMW 330Ci
Pic?
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
