Sponsored by BimmerWorld
Old 11-05-2010, 01:52 PM   #1
rhm325i
My Ride: 02 BMW 325i
H&r springs?
WHAT CONSEQUENCES HAVE ANY OF YOU EXPERIENCED THROUGH JUST THROWING ON SOME SPORT SPRINGS RATHER THAN SAVING UP AND BUYING SPRINGS AND SPORT STRUTS/SHOCKS AND SOME REINFORCEMENT PLATES AND NEW RSMs?
rhm325i is offline   Reply With Quote
Old 11-05-2010, 02:40 PM   #2
FTWeisse
My Ride: has no hip-hop rimz
Wasting money. That's the biggest consequence.
When I first started modding I bought springs.
A week later I realized it was horrible and needed shocks - so I bought Koni yellows.
For the price I could have bought a Bilstein PSS coilover kit.
Then I started going to the track so I bought a Bilstein coilover kit.
Wasted a bunch of money for springs and shocks I used for less than a year.
Moral of the story - do it once, do it right. It's cheaper in the long run.
Old 11-05-2010, 02:43 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The issue you will run into is paying labor twice (unless you DIY and like to take apart your suspension regularly ) by needing to replace the shocks down the line. Typically you get a better deal going with a matched spring and shock combo like the Koni FSD/Eibach Pro Kit or H&R Cup Kit.
Old 11-06-2010, 07:27 PM   #4
Bake
My Ride: AW F10 535 M-Sport
H&R Cupkit FTW!
Sent from my iPhone using BimmerApp
Bake is offline   Reply With Quote
Old 11-06-2010, 11:13 PM   #5
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Just save your money and do it right the first time.
I was able to buy my H&R springs + Bilstein Sports + front and rear adjustable H&R sways + O.E. strut mounts + RE rear shock mounts + O.E. front and rear sway bar endlinks + O.E. Outer tie rod ends (left and right) + Powerflex FCABS for roughly the same price as a Bilstein PSS10 system...
My only suggestions are like I said before, do it right the first time, and also buy the TMS strut tower reinforcement kit (well worth it).
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 11-08-2010, 01:57 PM   #6
rhm325i
thanks for all the input guys, i just put a staggered set of beyern mesh wheels on my car and was ready to drop it a couple inches, time to save up for the h&r cup kit and rsm's
