Problem! Loud rattle from underneath car at idle...now an oil leak too! - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-16-2010, 10:37 AM   #41
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by bigjae1976 View Post
The more I read into this, the more it sounds like either a bad slave cylinder or a bad throwout bearing.
Looks like I will have to pay some Korean hack mechanic to fix my car if a new slave cylinder won't fix it. Should be interesting...they do not have manual BMWs here in Korea. So I highly doubt anyone has a lot og experience with BMW clutches.
Taking the bellhousing off is the hardest part and that shouldn't be too different with a manual. Once you're inside things are pretty simple unless the pressure plate is coming off.
The noise made me think of the throwout bearing, but I wonder how a slave cylinder issue and a throwout bearing issue would be related. Two [perhaps absurd] things come to mind:
  1. The throwout bearing race seizes and the race bulges from the pileup(?) and that bucks the fork backward a little which overwhelms the slave cylinder and its seal blows. The rattle is the messed up bearing race.
  2. The slave cylinder doesn't retract all the way and spring tines of the pressure plate, which might be a little uneven, keep smacking the throwout bearing's pivoting face which you hear as a rattle.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-16-2010, 05:27 PM   #42
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Right now, I just want to get the car to the point where I can drive it to the shipping point so I can get it back to the US. Then fix the problem in the US.
I guess I need to come to grips that there is a good chance that I'll need to pull the bellhousing here. Need to find some external torx sockets.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 11-19-2010, 01:56 AM   #43
bigjae1976
bigjae1976's Avatar
Got the new slave cylinder. I popped it in the hole and bled it a little. I started the car while on jack stands, turned off the DSC and the rear wheels were turning. Obviously a little tough to shift since I didn't REALLY bleed the clutch that well.
I will remove the slave cylinder and bleed it properly out of the car this weekend. So I hope it was just a slave cylinder/hydraulic problem.
Old 11-19-2010, 08:35 AM   #44
McSpeed
Cool good luck!
Old 11-19-2010, 07:41 PM   #45
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Hope it works out for you!
Old 11-21-2010, 08:03 PM   #46
genuity
My Ride: 2001 330iS
Bump! Any updates on this?
genuity is offline   Reply With Quote
Old 11-21-2010, 08:41 PM   #47
bigjae1976
bigjae1976's Avatar
Bled the cylinder while it was out of the car...all seems to be well. I hope to get the car off of the jack stands tonight and test drive.
Old 11-22-2010, 11:20 PM   #48
bigjae1976
bigjae1976's Avatar
Still have a rattle and an engagement issue. Going to order a throwout bearing, fork, spring, and pin and then pull the tranny out.
Hoping its just the bearing and not the pressure plate or clutch. Then I might have to ask Santa for a UUC clutch kit.
Old 11-23-2010, 05:59 AM   #49
McSpeed
mannnn
well at least there'll be a lift involved- it should go pretty smooth
Old 11-23-2010, 06:05 PM   #50
bigjae1976
bigjae1976's Avatar
Hopefully...it seems like it would be a total whor3 to do it on jack stands. Crossing fingers my clutch and pressureplate aren't jacked.
Old 11-30-2010, 05:54 PM   #51
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Probably the TO bearing. Goodluck. Have fun having the tranny on your chest and knees
phamine is offline   Reply With Quote
Old 11-30-2010, 06:32 PM   #52
bigjae1976
bigjae1976's Avatar
Oh noes...I will be doing military presses with my 6 speed since I will be putting my car on a llift to do this.
I've got parts (the hold up in all of this)...just need to some free time! Hopefully I will finish this on Saturday.
Old 12-02-2010, 04:40 PM   #53
bigjae1976
bigjae1976's Avatar
Can a bad throwout bearing potentially cause my clutch to slip?
May the force be with me....I'll dive into this in about 9 hours!
Old 12-02-2010, 10:16 PM   #54
McSpeed
Not really - even if the throwout bearing was destroyed or missing the clutch wouldn't slip. It's just the thing that gets pushed into the pressure plate's lever tines to take pressure off the clutch disk. Clutch slippage would pretty much have to do with the clutch disk and/or the pressure plate.
Good luck in there!
Old 12-03-2010, 09:30 PM   #55
bigjae1976
bigjae1976's Avatar
Well...got the transmission off. Really not THAT bad on a lift. Took 2.5 hours for removal. 1 broken bolt, shouldn't be too bad to remove. Actually pretty straight forward. The hardest bolt to get out was one that I could see! If you are on a lift, you CAN see all 9 bolts if you tilt the engine back.
What happened? I pulled off the bell housing and the inside was covered with oil. The throwout bearing, arm, and pin seemed to be fine. The pressure plate looked good, all of the fingers were there. I took off the pressure plate and then WTF! One of the flywheel bolts was completely backed out. 6 were loose and 1 was tight. The backed out bolt was lodged between the pressure plate and flywheel which scored the inner metal part of the clutch. Not to mention that the flywheel is covered in oil.
So I need to order new flywheel bolts which will be installed with loctite. Basically I am dead in the water until some new flywheel bolts arrive...maybe 1 week. For the record, I did not do the clutch install.
Pics to follow.
Old 12-03-2010, 09:40 PM   #56
genuity
My Ride: 2001 330iS
^The source of the oil was a shot RMS right?
Old 12-04-2010, 06:25 AM   #57
bigjae1976
bigjae1976's Avatar
That's what I suspect. I am willing to bet the loose flywheel bolts is the source of the issue.
Old 12-04-2010, 07:11 AM   #58
bigjae1976
bigjae1976's Avatar
Spent all afternoon drilling out the bolt with dull drill bits...needless to say I didn't get very far. Korea suxs!
Old 12-04-2010, 07:48 AM   #59
McSpeed
Pics to follow.
Holy crap. Harmonics eh? I think the UUC flywheel does need different bolts : P
Old 12-04-2010, 10:18 AM   #60
aggieE46
Keep it clean
aggieE46's Avatar
The 5 speed UUC flywheel uses random bolts. Make sure you ask Rob for the right part number.
Glad you got it figured out, but this is exactly why I don't like taking my car to shops. At least if there's a goof-up it's my own fault for not doing it right... and I didn't pay someone else to do a poor job. Good luck!
