Sponsored by BimmerWorld
Old 11-07-2010, 10:20 PM   #1
McSpeed
My Ride: 2005 ZHP TT Stg 1
Is this brake line coupling...ok?
I came across this brake line coupling (?) that connects a hose to a hard line near the driver's side FCAB. I only ask about it because I thought I heard a hydraulic related noise when tightening a motor mount bolt and when I looked for the source this hose coupling caught my eye. I can slide the hose's metal coupling onto the hard line more, but it will return to the original position if I let go and if I push in the black plastic ring it will pop back out. Is this freedom of movement normal? Hopefully this isn't a completely silly question - I searched for a bit but I might've missed something.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-07-2010, 10:44 PM   #2
TrippinBimmer
My Ride: Just Fast!
Yes that is normal..Its a Quick Disconnect Hose.
-TrippinBimmer
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 11-07-2010, 11:07 PM   #3
McSpeed
Sweet thanks
Old 12-21-2010, 07:24 AM   #4
McSpeed
-TrippinBimmer
Is it possible/likely that brushing up against this could allow air into the brake line? A noise made me look at it initially and I wasn't sure if the noise was the sound of the mechanism sliding or a hydraulic seal breech.
EDIT: nm, I'm gonna bleed the whole brake system- I don't think it'd have made a noise I'd notice without some air going in, plus I'm already on jackstands and it's about time for a flush anyway
Old 12-21-2010, 01:40 PM   #5
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Nope, unless it leaking then its air tight..
-Anthony@BimmerBrakes
BimmerBrakes is offline   Reply With Quote
