Sponsored by BimmerWorld
Old 11-09-2010, 04:07 PM   #1
Zhpredlinez
My Ride: 2004 330i ZHP
Meyle HD/ECS poly/stock fcabs?
Well, I've been noticing some steering shimmy (oscillation of the steering wheel) when I first start driving and if I hit the brake too quickly, the steering jerks. I realize one could be tire balance, but I'm wondering if there's any method for checking those infamous fcab's while the car is in the air? It is EXTREMELY darty on uneven roads and I'm hoping I find a good alignment tech who can adjust the alignment to cause the car to not be so track worthy. I'm guessing less negative camber would help. I have read thead after thread about the poly bushings transmitting too much NVH and other say the Meyle HD's do as well. Is this pretty much "try it and see" or is there some consensus here? I don't and won't be tracking the car, but it would be nice to have some that last more than 30k miles if possible.
2004 330i zhp sedan, imola red
Zhpredlinez is offline   Reply With Quote
Old 11-09-2010, 06:34 PM   #2
InDiGlOM3
My Ride: HPF M3 stg 2.5
I have Rouge Engineering FCAB's and there is no added NVH that i can hear with my ears......
Old 11-09-2010, 07:21 PM   #3
McSpeed
My Ride: 2005 ZHP TT Stg 1
Maybe look for threads on the steering guibo too - or steering shaft flex disk - something like that - I remember people with tramlining issues replacing it and seeing a night and day difference even thought the thing appeared to be in good shape...
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-09-2010, 11:13 PM   #4
TrickTizzle
My Ride: 325i
RTABs
Old 11-10-2010, 10:29 AM   #5
GA-e46
My Ride: 2001 325i
whens the last time you had your breaks worked on? could be a warped rotor also
GA-e46 is offline   Reply With Quote
Old 11-11-2010, 08:15 AM   #6
Zhpredlinez
Thanks for the ideas. No, it's not something that happens when braking. I think it is getting progressively worse in the 2k miles I've put on the car too. It was acting so weird last night, I thought my front lug nuts might be loose. I guess I just need to put some fcabs on and check into the steering shaft flex disc as well. I guess it call also be an really whack alignment. Cars will drive like a freak if the toe is in or out drastically.
Could someone give me the correct part number for the compatible M3 rtabs? Thanks!!
