Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 1.00 average. Display Modes
Old 11-10-2010, 07:06 PM   #1
Bimmerboy330ci
My Ride: 2001 BMW 330ci
Boring a 3.0L engine
How big would i be able to bore my 3 liter engine?
I dont want to sell my car and get an M3 im just wondering for the car i have. Thanks
Bimmerboy330ci is offline   Reply With Quote
Old 11-10-2010, 11:28 PM   #2
TerraPhantm
My Ride: M3 & ZHP
I'm no expert, but from what I've read, it'd be pretty difficult to pull off. The cylinder walls are apparently already quite thin with pretty much no room to bore out and re-sleeve. With that said, I don't think it's impossible, since Hamann at one point was boring out m54s to about 3.2 or 3.3L
Old 11-11-2010, 01:06 AM   #3
mkodama
mkodama's Avatar
Boring an M54 engine is a waste of time and money if you want power. Getting a supercharger or turbo kit is the only way to go if you want to try and compare your engine power to an M3.
Old 11-11-2010, 06:06 AM   #4
///Orient3
My Ride: can't be defined
.5mm over...There isn't much more to be had.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 11-11-2010, 06:21 PM   #5
Jackcat559
My Ride: 2003 530
I went to 84.5MM easily. There's more left in the sleeve, but supercharging is more cost effective
Jackcat559 is offline   Reply With Quote
Old 11-11-2010, 08:58 PM   #6
TerraPhantm
My Ride: M3 & ZHP
84.5mm would make it ~3.05L, right? How much of an increase in power would you get?
Is boring to S52 displacement (86.4mm) possible?
Old 11-12-2010, 04:35 AM   #7
Jackcat559
My Ride: 2003 530
There's enough material on the steel liner, but I wouldn't do it. Add the costs of pistons, machine shop, labor and tuning and you could be at the cost nice supercharger kit, but probably less power than a supercharger.
Old 11-12-2010, 10:26 AM   #8
TerraPhantm
My Ride: M3 & ZHP
I'd imagine you can use the rotating assembly from an E36 M right? The crank is already the same.
And I know a supercharger would be much more cost effective - I was only asking for academic purposes. I probably won't put any more money into this car, I'd rather just get an M3
Old 11-12-2010, 01:19 PM   #9
tesko.pk
My Ride: 2003 530i
Alpina were able to go up to 3.3L with their E46 B3's.
tesko.pk is offline   Reply With Quote
Old 11-12-2010, 01:47 PM   #10
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Not an M54.
Old 11-12-2010, 07:47 PM   #11
TerraPhantm
My Ride: M3 & ZHP
Those were tweaked s50s iirc
Old 12-23-2011, 03:29 PM   #12
Hornung418
My Ride: '04 MB ZHP
Okay...so I'm bumping this because I'll be getting a spare M52TUB28 for free (Overheated). It will be taken apart and built for tracking. Looking to keep the displacement squared and use the S52 Crank (85.8mm). So I'm wondering if I can squeeze .9mm out of the cylinder wall/sleeve combo to get a total displacement of 2.976 Liters. In doing so, hopefully avoiding the Harmonic issues caused by the longer stroke of the M54B30. With the larger displacement I can theoretically run a Modified 330 MS43 DME. How low would this bring the Compression Ratio down to? And would it take to a turbocharger better than a super charger? Just trying to think outside the typical modifications on paper. Thanks guys.
Hornung418 is offline   Reply With Quote
Old 12-23-2011, 06:15 PM   #13
mkodama
mkodama's Avatar
Sounds like a lot of money, and a lot of hurdles, for no gains.
What issues with crankshaft harmonics have you already had on the track?
Old 12-23-2011, 08:39 PM   #14
Hornung418
My Ride: '04 MB ZHP
Got ahead of myself...no track car yet. This will be transplanted into an e30.
But...everything I've read about the tracked B30s have resulted in some sort of OPN failure and harmonic damper issues. I haven't read any with the B25 and B28, which have undersquare and square displacements. I'd like to see if this would develop these issues with a square displacement modified B30. I'm going to have new pistons and conrods anyway...it's not going to affect the price that much I don't think. Aside from the cost to Bore out the cylinder/sleeve combo .9mm to increase the total bore to 85.8mm, everything else was going to be bought no matter what. This is also a long term job so money isn't as much an object with this as it's more a whenever I have some spare cash kind of deal. Just doing the research.
So can you squeeze out .9 mm from the cylinder wall/sleeve combo in the M52TU/M54 block, and how would this affect the Compression Ratio?
Old 12-24-2011, 01:56 PM   #15
tinkwithanr
My Ride: '00 323i + '75 2002
Shouldn't really affect the compression ratio, mostly because you'll be having pistons made to whatever CP you want.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 12-24-2011, 02:14 PM   #16
Hornung418
My Ride: '04 MB ZHP
Okay thanks, tink! I forgot about that.
Sent from my DROIDX using Bimmer
Old 12-24-2011, 02:14 PM   #17
IMRD330Ci
My Ride: 330CI ZHP
Supercharger baby
IMRD330Ci is offline   Reply With Quote
Old 12-24-2011, 04:45 PM   #18
sedanpowersc
My Ride: 330i 5 speed
I remember seeing a german site a few months back that was selling stroker kits for b30's. They claimed 3.3l with a 40whp gain for like $8k. I wish I could remember the site, never checked again cause 8k wasn't reasonable.
Edit: found it, 3.3l making 286hp and 342Nm, at the low low cost of $11,800. But its for a brand new motor built in Germany.
sedanpowersc is offline   Reply With Quote
Old 12-24-2011, 05:10 PM   #19
mkodama
mkodama's Avatar
Sounds like the Alpina E46 B3 3.3, which somebody already mentioned wasn't an M54 or M52tu.
Old 12-24-2011, 05:36 PM   #20
sedanpowersc
Dunno, Idk anything about how they did theirs. Here's the link, says "3.3l engine (basis BMW M54 B30)" on the site
http://www.noellemotors.de/3_3l_engi...57d93e4.0.html
