Old 11-11-2010, 10:46 AM   #1
BB BMW
My Ride: 04 330ci ZHP
Check Engine Light on Cold Mornings
The past few days my check engine light comes on when going to work between 7-7:30am. The weahter is a little cooler now and the mornings are around 35-40 degrees. The check engine lights comes on when I leave the house and usually goes off after traveling about 8-10 miles. It does not come on when I leave work later that evening around 5-6pm. This only happens in the morning.
I know I could get a Peake Code reader, but wanted to know if anyone else had run across this before.
I guess I'll go by AutoZone this weekend and see if they can get me the codes.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
Thomas Jefferson
BB BMW is offline   Reply With Quote
Old 11-11-2010, 12:05 PM   #2
jcns
My Ride: California
are you checking check engine light or SES light?
jcns is offline   Reply With Quote
Old 11-11-2010, 12:36 PM   #3
BB BMW
The light that looks like a motor.
Thomas Jefferson
Old 11-11-2010, 01:51 PM   #4
shanneba
My Ride: 2003 330Ci
Do you get the light when your fuel tank is full?
Do you drive the car at lunch time?
Since the test runs from 20F to 95F, I am not sure what might cause the error when it is colder out.
This may be why you see it only in the mornings-
http://www.bmwmotorsports.org/BMW_docs/m54x5.pdf
LEAK DIAGNOSIS TEST PRECONDITIONS
The ECM only initiates a leak diagnosis test every second time the criteria are met. The criteria
are as follows:
• Engine OFF with ignition switched OFF.
• Engine Control Module still in active state or what is known as “follow up mode” (Main
Relay energized, control module and DME components online for extended period after
key off).
• Prior to Engine/Ignition switch OFF condition, vehicle must have been driven for a minimum
of 20 minutes.
• Prior to minimum 20 minute drive, the vehicle must have been OFF for a minimum of 5
hours.
• Fuel Tank Capacity must be between 15 and 85% (safe approximation between 1/4 -
3/4 of a tank).
• Ambient Air Temperature between -7C & 35C (20F & 95F )
• Altitude < 2500m (8,202 feet).
• Battery Voltage between 11.5 and 14.5 Volts
When these criteria are satisfied every second time, the ECM will start the Fuel System Leak
Diagnosis Test. The test will typically be carried out once a day i.e. once after driving to
work in the morning, when driving home in the evening, the criteria are once again met but
the test is not initiated. The following morning, the test will run again.
Join BMWCCA
Old 11-11-2010, 02:05 PM   #5
Penguin Koolaid
Banned
My Ride: Inline Six
Like a motor... is your vehicle a non-US model? Do you see the light indicated anywhere below:
I have issues during cold weather with a post-cat oxygen sensor running lean. It remains lit though for months until temperatures return to a normal state.
Penguin Koolaid is offline   Reply With Quote
Old 11-11-2010, 03:15 PM   #6
eneka
My Ride: 2003 325i
maybe it's the low coolant light?
eneka is offline   Reply With Quote
Old 11-11-2010, 03:18 PM   #7
BB BMW
2004 330CI US MODEL
See pic below
Thanks for the cluster pic, I'm at work and didn't have access to a desktop editor.
Thomas Jefferson
Old 11-11-2010, 03:34 PM   #8
jcns
My Ride: California
check your radiator/expansion tank level.
Add distilled water/coolant mix as needed.
Old 11-11-2010, 03:52 PM   #9
BB BMW
Thanks jcns.
So it's a radiator light, the thing looks just like the check engine light on the Acura Legend I had. Guess I should have drug out the owners man.
Thomas Jefferson
Old 11-12-2010, 11:22 AM   #10
Peake Research
Past Site Sponsor
My Ride: E46
Definitely the coolant indicator in this case...
FYI, older E46s use an engine symbol, newer ones say "Service Engine Soon". Both these warnings indicate the identical condition - fault code(s) have been generated due to an engine problem being monitored.
Best of luck,
Ken
Peake Research is offline   Reply With Quote
Old 11-12-2010, 11:44 AM   #11
shanneba
My Ride: 2003 330Ci
Canadian models also use an engine symbol in place of the US "service engine soon" light.
Electronic owners manual download- for reference:
http://www.linquist.net/motorsports/bmw/3manuals/
Join BMWCCA
Old 11-12-2010, 11:58 AM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Rtfm
Old 11-12-2010, 02:42 PM   #13
Silver325
My Ride: 2002 325i
OP, my car did the same thing last year. I topped the coolant and the light went out. However, the seal at the bottom of the expansion tank was beginning to fail. I never saw any coolant on the ground or in the engine compartment. Seemed to evaporate as it leaked, but the leak reached the point where I had to top off the coolant every day. I replaced the expansion tank (along with hoses, water pump, flush, the whole thing because it was time) and it was fixed. So, keep an eye on it. You may just need a top off, but these cars are known for issues with the expansion tank.
Meyle control arms, M3 RTAB's, Bridgstone Potenza RE760
Silver325 is offline   Reply With Quote
Old 11-12-2010, 04:54 PM   #14
Penguin Koolaid
Banned
My Ride: Inline Six
2004 330CI US MODEL
See pic below
That's supposed to represent a coolant tank. It's not an engine .
Check your coolant level when the car is cold (i.e., has been sitting for several hours; it's very important). If it's low, simply top it off with some distilled water. You can get a gallon at a place like Walmart for $1.50. Be careful when topping it off, as it can go from low to too full very quickly.
