Help with Cams - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-12-2010, 02:43 PM   #1
abrogan0319
My Ride: M3 6spd
Help with Cams
yes i have searched
looking for what cams to select for a 2000 323ci platform.
a local 2002 330ci is parting out. any gains from those cams?
ECS also has a kit
http://www.ecstuning.com/BMW-E46-330...mance/ES17871/
would these possibly work? possible gains?
anyone with a 323 running any cams with some advice
just looking for some options
this is the daily driver, and im aware its just a 323ci. so leave the negative comments to yourself. just looking for a little more spark to the car for spirited drives. thanks
abrogan0319 is offline   Reply With Quote
Old 11-12-2010, 02:52 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
If you're going to go to the trouble of doing cams, put in Schrick cams.
Also, have you looked into the 330 intake manifold swap? Seems like it makes some nice gains.
Old 11-12-2010, 03:06 PM   #3
abrogan0319
My Ride: M3 6spd
what Schrick cams? ive been on websites.. i know turnermotorsports has some Schrick cams, but i havent really pin pointed any for a 323 platform
which cams should i be looking at?
is it possible for the stock 330ci cams to make any types of improvement in a 323?
Old 11-12-2010, 03:12 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
The ones Turner sells are the right ones.
Have you looked into installing cams? You'll need several special tools running several hundred dollars. The 330 has a slightly more aggressive cam. Can't remember if it's the intake or exhaust. Not worth it for all the labor and expense involved.
Old 11-12-2010, 03:54 PM   #5
TrickTizzle
My Ride: 325i
Originally Posted by abrogan0319 View Post
yes i have searched
ECS also has a kit
No, Those are ZHP cams for B30's only.
Old 12-02-2010, 07:28 PM   #6
bigdog2003_99
My Ride: 2009 Audi B8
+1 i did my own cam job, the tools are around 300$ and the install was a pita. if you do it, go shrick, because it would not be worth the work if not...
btw the cams are hollow and if you do it wrong you will break them
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 12-03-2010, 02:25 AM   #7
Iceman00
Banned User
My Ride: E90 6MT
The B30 Intake cam has 9.7mm of lift and a duration of 240 vs 9.0mm of lift and 224 degrees of duration for the others. Not worth it
