Old 11-13-2010, 08:22 PM   #1
e46techtuner
My Ride: 2000 328i
2000 328i Dyno
Went to a local shop today to get my car "dynoed" for the first time, using a Dyna Pack dynometer. Car is pretty much bone stock(powerwise) 2000 328i with the 5 speed manual transmission. Just have a Conforti air intake, UUC TSE3 cat-back exhaust and Redline oil in the trans. and diff. Car has 96k miles on it. Outside tempature was about 70 degrees.
First pull got a reading of about 170hp. It kept getting higher by a couple hp each pull until it hit 178.3hp with 197.0 ft/lbs of torque. After that, it would just get a max reading of about 177hp.
e46techtuner is offline   Reply With Quote
Old 11-13-2010, 08:47 PM   #2
HakenTT
My Ride: 323i with S54
What sucks is that a 1995 nissan maxima se makes 177hp at the wheels bone stock. And it is family economy car.
HakenTT is offline   Reply With Quote
Old 11-13-2010, 08:53 PM   #3
Iceman00
Banned User
My Ride: E90 6MT
The Altima was an economy car, the Maxima was a mid size sedan. I don't consider any car that comes with a V6 motor standard as an "economy" car.
VQ ftw.
Old 11-13-2010, 08:53 PM   #4
Iceman00
Banned User
My Ride: E90 6MT
Have a graph for me?
Old 11-13-2010, 11:05 PM   #5
Recon2005
My Ride: VF-E 328Ci & 325 E90
I assume you are in Phx...where did you dyno?
Vortech // Magnaflow // Hotchkis // H&R
Originally Posted by Forcefed M3 View Post
Could not agree more. I enjoyed my vf kit to the day I took it off. VF best s/c out there. Period
Recon2005 is offline   Reply With Quote
Old 11-13-2010, 11:55 PM   #6
McSpeed
My Ride: 2005 ZHP TT Stg 1
There's no comparing these cars if you drive them...and the tire squealing got old before I was done with the maxima test drive.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 11-14-2010, 01:52 AM   #7
e46techtuner
My Ride: 2000 328i
My girl friend use to own a 95 Maxima. The E46 is a lot more fun to drive, stock vs stock. I consider E46's family/economy cars(seats 4, 30+mpg).
I didnt get a graph, since it was a Dyno Day/BBQ and they were just getting cars in and out doing baselines. I will ask and see if I can get one.
I went to UMS Tuning in Mesa. www.umstuning.com
They were doing dyno/weight for the UMS Tuning Time Attack Series classing for next year.
Old 11-14-2010, 08:46 AM   #8
Recon2005
Thank you, nice numbers BTW.
Old 11-16-2010, 04:12 AM   #9
e46techtuner
My Ride: 2000 328i
I got these today.
ID:	383890   Click image for larger version
Old 11-16-2010, 10:20 PM   #10
Recon2005
You mentioned this session was for baseline numbers; but any plans for tuning? Did they measure AFR's?
Old 11-16-2010, 11:21 PM   #11
RockerGuy
My Ride: Not a BMW
I used to think we had 190 hp, I have the same car.
RockerGuy is offline   Reply With Quote
Old 11-17-2010, 12:35 PM   #12
murph1379
My Ride: 2006 M3
You do. At the crank.
murph1379 is offline   Reply With Quote
Old 11-17-2010, 02:00 PM   #13
RockerGuy
My Ride: Not a BMW
Hate when manufacturers measure at the crank. Waste of time. I am not buying an engine, I am buying the whole car, lol
Old 11-20-2010, 04:21 AM   #14
e46techtuner
My Ride: 2000 328i
I didnt measure the Air/Fuel ratio since Im not planning on tuning. I am trying to class my car for NASA Time Trials TTE class, so my car is pretty much maxed out on modification points.
Old 11-20-2010, 09:26 PM   #15
darkapollo
My Ride: 2000 328i ZSP
Because the specific out put of the engine can be better measured at the crank then through the drive line, trans, and diff, even the tire pressure and tension of the straps holding the car down. All of which can change the numbers.
Sent from my HERO200 using BimmerApp
darkapollo is offline   Reply With Quote
Old 12-04-2010, 11:51 AM   #16
e46techtuner
My Ride: 2000 328i
Here is a dyno video I thought, I would share:
Old 12-05-2010, 05:18 PM   #17
Steven747
My Ride: 05 330ci
thats what happens to evoss! hahahahaha
Old 12-06-2010, 04:56 PM   #18
GA-e46
My Ride: 2001 325i
just me or did they use one strap wrapped around once?
GA-e46 is offline   Reply With Quote
2000 328i dyno
