Sponsored by BimmerWorld
Old 11-14-2010, 11:12 AM   #1
autograff323
My Ride: One nice BMW
New suspension going in bushing ?
I'm putting in a coilover suspension this week and wanted to get your opinions on what bushings should be changed. The car is a 99 and it has 92 thousand miles never changed any bushings before. I know that the front control arm bushings should be changed but thats about it. Let me know what you think. Thanks
autograff323 is offline   Reply With Quote
Old 11-14-2010, 05:33 PM   #2
HP Autowerks
Past Site Sponsor
My Ride: E36 M3
I would also change the front control arms (this replaces the ball joints). Also, I would change the RTAB (rear trailing arm bushings) if they have a lot of movement which they most likely will.
HP Autowerks is offline   Reply With Quote
Old 11-14-2010, 05:37 PM   #3
w0w
My Ride: '02 M3 Vert
what coilovers are u putting in? you might want to replace the endlinks as well
daron
w0w is offline   Reply With Quote
Old 11-15-2010, 06:58 PM   #4
autograff323
Putting in the pss10's and I need the strut mounts my mechanic said. So the control arms and everything that comes with that and the rear trailing arm bushings, Maybe the end links. I'm just looking to get everything done right so I can have this car run like it should. Anything else?
