E46 Xi Forum
Old 11-15-2010, 10:09 PM   #1
EDness
My Ride: 2004 BMW 325xi
front diff fluid change
Sorry this is my first post. I usually do all the maintenance of my cars myself and I just bought this car as my winter car.
I've been searching for a DIY for front diff fluid change...I've found the rear diff and transfer case but not the front diff. Just want to get some info before i tackle the job.
thanks
EDness is offline   Reply With Quote
Old 11-16-2010, 07:46 AM   #2
ferngreen 325xi
My Ride: 2001 325XI wagon.
To make it easy, take off the front driver side tire to refill the pumpkin.
ferngreen 325xi is offline   Reply With Quote
Old 11-16-2010, 10:00 AM   #3
SILVRRONIN
My Ride: 2003 325.xit
Go to DIY BMW differential fluid change( google). Its easy..I used the expensive differential fluid-purple stuff 75-90.
SILVRRONIN is offline   Reply With Quote
Old 11-16-2010, 10:18 AM   #4
EDness
They are all for the rear which i've found. I'm looking for the front diff...just want to make sure where the fill and drain plug is. I'm sure I'll find out when i look at it...i just want to see if online before i go tackle it.
Old 11-16-2010, 11:46 AM   #5
GCoop
My Ride: '04 325xi
You will be fine. its fairly obvious once you take a look. In any case here is a diagram:
Drain on the bottom (#10) Fill on the side (#10)
GCoop is offline   Reply With Quote
Old 11-16-2010, 04:16 PM   #6
SILVRRONIN
Look fro the bottom plug to drain. Then open the top and use a small hand pump(wall mart $8 found in the marine outboard section) to suck it all out. Then go to the top...remove plug using hexhead. Pump all the new fluid in. The recommendations are in the article.
Old 11-16-2010, 04:18 PM   #7
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
^ make sure to loosen the top one first to make sure you can get it open before you drain your fluid by opening the drain one..
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 11-16-2010, 07:10 PM   #8
Kubica
My Ride: 2003 325xi
The bottles of Motul fluid with the extendable long skinny penis-type spout makes filling it very easy, btw.
Old 11-16-2010, 07:46 PM   #9
athayer187
My Ride: 2004 330xi
hahaha
If you're not down with playing with penis, the bottle pumps you can get at Autozone or Advance Auto work great too.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 11-16-2010, 08:13 PM   #10
chuckb
My Ride: 2001 330xi
use an extension to get at the fill bolt. I used my impact gun that way and it flew off.
chuckb is offline   Reply With Quote
Old 11-17-2010, 12:11 PM   #11
EDness
thanks guys. I'm going to change the fluids out once the fluids gets in. Also doing an bunch of other stuff as well. Fuel filter, spark plugs, oil change, clean ICV...and a full exterior detail. It's swirl city at the moment.
Old 11-17-2010, 02:49 PM   #12
wdeerfield
wdeerfield's Avatar
I had my fluid changed by an indy using bmw diff fluid, but now i fear i have a leak (possibly one of the plugs) and might be low. im going to do this change myself and replace the drain/fill plug washers. Which fluid do you recommend? which motul?
Old 11-17-2010, 04:11 PM   #13
GCoop
My Ride: '04 325xi
The original fill was SAF-XO which is/was a synthetic GL5 75W-90 Gear Oil.
Any synthetic 75w-90 GL5 spec gear oil will be fine. I used Redline 75W90
Old 11-17-2010, 05:03 PM   #14
chuckb
My Ride: 2001 330xi
red line +1 deerfield. Turner Motorsport sells the redline kit for diffs, transfer case, and man trans. That's what I bought.
edness- i just did a fuel filter on my 01 and it needed new hoses and pipe clamps. 3 little pieces of fuel hose, and 6 small pipe clamps later i was good as new.
Old 11-17-2010, 07:41 PM   #15
Kubica
My Ride: 2003 325xi
Originally Posted by athayer187 View Post
hahaha
Hey Andy- yeah I have one of those, and I also have one of the syringe style suction guns. I bought the suction gun because I always made a little mess with the hand pump. Suction gun worked great until the plastic tube fell off while I was filling, which made a Big mess. I had a buddy bring over some 75w90 because my remaining redline was on the floor- thats how I discovered the Motul trick.
Yeah a 3-4" extension between a 3/8" ratchet and the socket works great and you def dont have to take the wheel off.
I used the Motul 75w90 (300 I think) because that's what my buddy had in his garage when I called him. I'd recommend Redline. I've used Royal Purple too because it was available at Autozone and I was too lazy to drive to HMS, turner, or bav.
Old 11-17-2010, 09:45 PM   #16
TiAgXi
My Ride: e46xi, e46m
What's the consensus on whether the car has to be level to properly fill the diff? I've always put the car on stands before doing this job but I've always wondered if it was truly necessary.
TiAgXi is offline   Reply With Quote
Old 11-18-2010, 09:01 AM   #17
SILVRRONIN
Place the car on ramps to drain....keep it even when filling. Autozone sells the PURPLE KING synthetic fluid..75-90...awesome stuff..
Old 11-18-2010, 02:19 PM   #18
SILVRRONIN
who has changed their transfer case fluid? is anyone using the purple king? of the Redline d4 atf?
Old 11-18-2010, 05:02 PM   #19
SamDoe1
My Ride: 4cyl of fury
Use the same stuff that went into your manual transmission. If you don't have a manual, then just use MTL. I used Royal Purple Synchromax.
Old 11-18-2010, 06:48 PM   #20
325xi.bimmer
My Ride: '04 325xi
Isn't MTL (manual transmission lubricant) for use if you DO have a manual transmission?
325xi.bimmer is offline   Reply With Quote
