Sponsored by BimmerWorld
Old 11-16-2010, 03:30 AM   #1
TerraPhantm
My Ride: M3 & ZHP
PSS10 vs KW V3?
I was about to pull the trigger on PSS10s, but I saw that the KW V3s are only $100 more than the PSS10s right now... Does anyone have experience with both of these coils? How do they compare? People seemed to be pretty torn between PSS10s and KW V2 - would the V3 be superior to both?
Old 11-16-2010, 09:51 AM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The V3s are rebound and compression adjustable so you get the extra adjustment. However, I think the PSS10s are a better quality system so I would go for those unless you absolutely need the 3 way adjustment.
Old 11-16-2010, 11:44 AM   #3
McSpeed
My Ride: 2005 ZHP TT Stg 1
Also - in case this is new info - PSS10's are pretty harsh even on the softest setting. I think I heard KW's can be set pretty close to ZHP stock.
I'm leaning toward TCK's (because they can do stock ride height) w/ Swift springs (because I hear they can perform great while keeping the ride smooth).
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
