///M3 Forum
Old 11-17-2010, 04:28 PM   #1
newportcgt
My Ride: 04 M3
M3 Convertable Top
I just purchased an 04 SMG M3 convertible. The car came with the hard top. I didn't really care for the look so I sold the hard top to a fellow M3 owner and allowed him to take the hardware kit from the car. now the top seems to not be working and the red light is flashing. I held the button down as the owner manual states but nothing. Does anyone have any experience with this and do I need that hardware kit for it to work. Thanks
newportcgt is offline   Reply With Quote
Old 11-17-2010, 04:52 PM   #2
TMQ
My Ride: Golf R, E46 330CiC
Send a message via MSN to TMQ
are you trying to drop the top? cause you may not have the roof compartment clear in the boot, which would cause it to blink
TMQ is offline   Reply With Quote
Old 11-17-2010, 08:26 PM   #3
newportcgt
My Ride: 04 M3
I am trying to drop it however I did check and make sure that the cargo deal was down all the way
Old 11-19-2010, 06:16 PM   #4
M00P
Location: El Pueblo Nuestra Senora la Reina de los Angeles de Porciuncula
My Ride: e46 m3, e36 sedan
I had this happen to me and the trunk wasn't closed all the way. Looked closed but the instrument cluster indicated otherwise.
M00P is offline   Reply With Quote
Old 11-21-2010, 08:10 AM   #5
ianmason
My Ride: '05 M3 Vert
THe times I've had issues with the top is when the car thinks the trunk isn't closed, which is just a faulty switch, and when the car thinks it's in gear.
Unfortunately I don't know a thing about the hardtop, so I can't comment. But I'm sure you didn't hurt anything.
ianmason is offline   Reply With Quote
Old 11-21-2010, 07:41 PM   #6
chlippo
My Ride: M3 2002 Convertible
hardtop have nothing to do with that....
chlippo is offline   Reply With Quote
Old 11-22-2010, 04:04 PM   #7
LSBM3NM
My Ride: 2002 M3 Conv.
http://www.m3forum.net/m3forum/showt...onvertible+top
I had the same problem after removing my hardtop. Softop would make clicking noise but make no progress in moving up or down. I removed the rear seat and pushed on the lid to the black box (has the convertible top motor inside) with one hand and pushed the top down button with the other hand. It worked perfectly! Turns out the plastic gear on the box lid grinds down over time and the link above has an awesome diy to help provide a fix to the issue.
*You ultimately wrap a hose clamp around the box with dowels or something equivalent wedged between the clamp and box lid. I hope this helps.
LSBM3NM is offline   Reply With Quote
advice, convertable, e46
