Old 11-17-2010, 11:49 PM   #1
SonnyT
My Ride: 01 325ci
Some questions about a few codes
Codes are from my baravian code reader. Looking for causes and solutions
Table 19
8f: dm-tl leak detected
A8: coolant thermostat jammed opened
1d: ignition coil #1 (this one seems straight forward)
SonnyT is offline   Reply With Quote
Old 12-01-2010, 06:42 PM   #2
e46crooser
My Ride: 99 328 5spd
8f- leak in evap emissions system (could be loose gas cap or a vacuum leak at evap solenoids at rear of engine compartment)
a8- replace thermostat
1d- you answered it. Swap coils and if misfire moves then you know you have a bad coil, if it stays you have another issue (like fuel injector, but hey how often to bmw's have problems with fuel injectors? If it was an Audi then i'd say coil and injector .
HTH Phil
e46crooser is offline   Reply With Quote
