Sponsored by BAVSOUND
Old 11-21-2010, 05:16 PM   #21
Bjorn8781
My Ride: BMW 320Cd 2005
I have the HK stock amplifier as well. I got it from a friend of mine, but since my car doesn't have the wires for the amplifier, it is useless.
What we need is some help from someone showing us which wires we must use to connect an amplifier, sub etc...
Bjorn8781 is offline   Reply With Quote
Old 11-22-2010, 08:20 AM   #22
Bjorn8781
anybody can help??
Old 11-24-2010, 11:56 AM   #23
Al1enjr
My Ride: BMW 328I
below is the pic inside the trunk of my 3 series. 5 amps and 3 batteries. Do run these you need to bypass or get rid of the factory amp all together. Run RCA wires back from the head unit, then connect to the battery. Done!
Al1enjr is offline   Reply With Quote
Old 11-25-2010, 06:02 AM   #24
zaharias
My Ride: M3 E46 6MT 3/2005
Nice install but i don't want something like this..
There is no OEM (factory) amp in our cars..
We have the completely stock-simple system with 2 speakers front with twitters and two speakers rear and i guess there is a built in HU amp.. No amp at the trunk, no harness..
So we want to know where to connect the amp, which wires to cut and what type of wires should we use..
zaharias is offline   Reply With Quote
Old 11-26-2010, 05:00 AM   #25
zaharias
I also found this http://forum.e46fanatics.com/showpos...7&postcount=44
Old 11-26-2010, 06:54 AM   #26
zaharias
I made my move and bought some Rainbow speakers..
Rear..
Front..
http://www.bigdogaudio.de/lautsprech...-und-coup.html
Also bought an AudioControl LC6i LOC..
http://outlet.crutchfield.com/S-WDYu...=02&tab=review
And i want to buy the PDX-5 and a sub, that i haven't decided which one yet..
Old 11-30-2010, 07:33 PM   #27
miaM7
My Ride: 04 325i Sp
Hi, I will attempt to do something similar, but I will try the preout DiY on our HU. Check my post (speaker level output) for some tips and explanations. http://forum.E46Fanatics.com/showthr...2#post12518932
As for wiring, you just tap into the connector and route to the rear. Now how to route to the rear will be the fun part! When I get to that part, i'l share my experiences.
miaM7 is offline   Reply With Quote
Old 12-06-2010, 05:08 PM   #28
zaharias
I got the fronts today..
Back side..
Testing..
OEM twitter bye bye..
Rainbow twitter
Crossover
Fitted..
Old 12-07-2010, 01:05 PM   #29
zaharias
Rainbow on top, OEM under..
Comparisson
OEM speaker 16cm
Rainbow 16cm
The OEM speakers are 13cm (5.25")??
Old 12-07-2010, 04:29 PM   #30
zaharias
The rear speakers arrived today..
Old 12-07-2010, 10:52 PM   #31
aar0n_91
My Ride: 04 BMW325CI///MSport
i just bought 2 sets of soundstream RF-60C component speakers to replace the front and rear HK speakers that came with my car. they are 6.5" wide and have a mounting depth of 2.6". i was wondering how your 6.5" rainbows fit in the door, can you reuse the oem speaker grills??
i also bought a soundstream tarantula T5-12 900W RMS sub, soundstream tarantula TX1.2000D 2000rms monoblock amp to power it, a soundstream picasso PX4.760 4 channel 760rms amp to power the speakers and a soundstream INT.2BX eqaliser to tune all the gear whilst keeping the factory 16:9 widescreen HU installed.
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 12-09-2010, 04:56 AM   #32
zaharias
Euro spec cars have differences with the US spec.. Mine also is non HK..
As you can see no adaptor ring is required for the front.. I reused the factory screws.. And i didn't remove the OEM adapter..
I think that is required at the rears.. I will fit the rears one of these days..
The speakers are direct fit and are made for BMW E46 coupe to fit factory speaker places..
Old 12-14-2010, 06:50 PM   #33
zaharias
I removed this today to make some room for the Alpine..
Old 12-14-2010, 06:58 PM   #34
zaharias
I found a harness at the back..
Is this for navi?
Old 12-15-2010, 01:21 AM   #35
zaharias
I removed the c pillars and the rear deck yesterday...
You have to remove the c pillars first..
You remove the light first with a flat head screwdriver and then you can see a torx screw..
They also have 2 clips.. You have to pull up and front (towards the front of the car) and with a bit of patience they come out.. Be careful cause it's very easy to break something..
Then you have to remove these clips.. You have to lie down into the trunk and push them from the down side to pop up a bit and then it's easy to remove them..
Old 12-15-2010, 01:38 AM   #36
zaharias
To remove the headrest you have to pop up abit the shelf and look underneath.. You must remove 2 metal clips at each headrest and then you take them out..
Then you remove the speaker grill with a small flat head screwdriver and by removing 3 8mm bolts at each speaker, disconect the plug and you get rid of these also..
Then you have to remove the speaker housing..
Old 12-15-2010, 01:45 AM   #37
zaharias
Then you have to remove the rear seatbelts and it's out..
Old 12-21-2010, 01:21 AM   #38
zaharias
The AudioControl arrived yesterday..
Old 12-25-2010, 09:46 PM   #39
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
where can i buy a LOC?
Originally Posted by zhp43867 View Post
You're going to need a Line Out Converter or LOC, I am just trying to help determine for you which wires to attach the LOC to. You have Front Right, Front Left, Rear Right, Rear Left Speakers.
Buy two two channel LOCs if you want "4 Channel" input, which I recommend. You then connect each pair (front and rear) speakers to the two LOCs. That will give you RCAs to run into your amplifier.
From where can I get a LOC,?
My 2nd question is that, I want to install an aftermarket amplifier and subwoofer, I don't want to make any changings to stock stuff ( i dont wanna mess around with it).? thank You
rizwan1377 is offline   Reply With Quote
Old 12-25-2010, 10:12 PM   #40
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
You can get them from several sources. Crutchfield is just one of many examples.
Here is a good place to start;
http://www.google.com/search?q=line+...ient=firefox-a
Decide if you need 2, 3, 4, 5, or 6 channels and get the appropriate LOC.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
