Sponsored by BimmerWorld
Old 11-20-2010, 10:58 PM   #1
E46riderz
My Ride: e46 330ci
I need help bad metal grinding noise
replaced the rotors thought it would fix my problem on the E46 but metal grinding noise is still there. as soon as pull off the noise starts instantenous can somebody help me any suggestions?
E46riderz is offline   Reply With Quote
Old 11-20-2010, 11:01 PM   #2
E46riderz
My Ride: e46 330ci
Sorry rear passenger side.
Old 11-20-2010, 11:08 PM   #3
GTB323
My Ride: 2000 323ci
Give more details!...friend had a grinding noise one time i think it ended up being his wheel bearing
GTB323 is offline   Reply With Quote
Old 11-21-2010, 01:24 PM   #4
E46riderz
My Ride: e46 330ci
really loud grinding noise from rear passenger side it starts as soon i pull off i give it gas seems like it stops as soon i let go of gas pedal it starts the grinding noise
Old 11-21-2010, 01:32 PM   #5
TrippinBimmer
My Ride: Just Fast!
Thought I said Check Wheel Bearings. Also, Check the Ring and Pinion in the rear Diff.
-TrippinBimmer
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 11-21-2010, 03:57 PM   #6
E46riderz
My Ride: e46 330ci
thanks ima chek it out
Old 11-29-2010, 11:45 PM   #7
cconover
My Ride: 2003 330i ZHP
May want to check your parking brake assembly as well. If that's starting to fail at all then it could be grinding against the inside of the brake hat.
cconover is offline   Reply With Quote
