Sponsored by BimmerWorld
Old 11-22-2010, 07:37 PM   #1
so simple
My Ride: non bmw
Parking brake not working, already adjusted, replace shoes?
2000 328Ci.
Car has about 85k on it, I've never replaced any braking component since I purchased it around 71k. Pretty much since I've had the car, the parking brake does not work well. If I'm on a slant or hill, the brake is pretty much no good. I have adjusted the brake both ways, by adjusting under the parking brake lever, and by following the Pelican article on adjusting at the rear wheels.
I was thinking about getting new pads and rotors, but was hesitant, because my braking system seems to work fine driving, just no parking brake. But I recently read that the parking brake is independent of rotors/pads and is a rear parking brake shoe?
If I replace the brake shoes, is it likely my parking brake will start working on hills etc? Also, is it a simple DIY or just let a shop do it?
so simple is offline   Reply With Quote
Old 11-29-2010, 11:44 PM   #2
cconover
My Ride: 2003 330i ZHP
Originally Posted by so simple View Post
2000 328Ci.
The parking brake is independent of the primary braking system. There is a parking brake assembly (shoes, springs, etc.) inside the brake hat in both rear wheels, so anything you do re: pads & rotors will have no affect on the parking brake. I'd recommend taking off the rotor & inspecting the brake shoes & all other mechanical parts of the parking brake.
As far as the difficulty of replacing brake shoes I can't speak to that as I've never done it, hopefully somebody else can share some insight on that.
cconover is offline   Reply With Quote
