Anyone with Meyle Control Arms and/or Koni Yellows? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 11-25-2010, 12:29 PM   #1
Turd Furgasun
My Ride: '02 330i Sedan
Cool Anyone with Meyle Control Arms and/or Koni Yellows?
I'm actually trying to remove them from the car (swapping springs for winter). But there isn't enough clearance to remove the Strut body from the spindle.
I've read that the Meyle arms don't have as much movement; I'm short about 1" clearance... tried moving the wheel, etc. with no change.
If you have installed/removed Koni's with Meyle arms, did you have the same issue?
Any tips? Thanks.
Turd Furgasun is offline   Reply With Quote
Old 11-25-2010, 11:06 PM   #2
BodyMan
My Ride: 2002 325i
You might try unbolting the bushing end of the control arm.If that fails, disconnect the ball joint at the spindle.
BodyMan is offline   Reply With Quote
Old 11-25-2010, 11:12 PM   #3
mvrk10256
My Ride: E30 325i
The control ARM should not be a problem. I would just play with It. Make sure u fully loosen the bolts that hold the strut in place. Then push down so the plates clear and rotate the assembly till it pops out.
Sent from my PC36100 using BimmerApp
Old 11-26-2010, 11:59 PM   #4
BodyMan
My Ride: 2002 325i
It shouldn't, but it does happen.
Old 11-29-2010, 07:09 AM   #5
Turd Furgasun
update: I had to compress the springs on the car for removal.
