Sponsored by BimmerWorld
Old 11-28-2010, 08:25 PM   #1
Dreamliner330
My Ride: 330xi
Strut / shock / spring replacement, I give up...damn you!
[rant]
I tried replacing my springs and shocks today...and failed.
First
I took out the front strut, after I realized the sway bar end link was not OEM and I needed a wrench and a torx to remove it.
Then
The damn strut wouldn't come out of the brake/rotor assembly.
Then
The damn spring compressors weren't able to get all the coils.
Then
I couldn't get the top strut nut off trying to use a spark plug socket, wrench and a 6mm allen wrench.
Then
I broke the 6mm wrench I was using for leverage to hold the 6mm allen wrench.
Then
I went to Sears looking for a allen socket with a super long allen part
Then
The retard sales clerk convinced my a allen wrench with a big handle grip would work.
Then
It didnt work.
Then
I realized the BMW strut design is
Then
I put the original stuff back.
Now
I am complaining about it.
Tomorrow
I will pay a mechanic to do it for me.
And...
FML.
[/rant]
Dreamliner330 is offline   Reply With Quote
Old 11-28-2010, 08:32 PM   #2
tootall
My Ride: 2011 328iT 3 pedals
The shade tree mechanic must eventually know his/her limits.
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 11-28-2010, 08:33 PM   #3
Dreamliner330
My Ride: 330xi
^I've done it in other cars without incident...It's not like I was out there with sticks and rocks...
Old 11-28-2010, 11:08 PM   #4
Recon2005
My Ride: VF-E 328Ci & 325 E90
Spring compressors are from Hell!!! Spent 3 hours wrestling with those pieces of garbage because I thought I was slick. I finished the driver side but gave up on the passenger side and let Pepboys take care of swapping the spring for me. I feel your pain.
Vortech // Magnaflow // Hotchkis // H&R
Originally Posted by Forcefed M3 View Post
Could not agree more. I enjoyed my vf kit to the day I took it off. VF best s/c out there. Period
Recon2005 is offline   Reply With Quote
Old 11-29-2010, 11:28 AM   #5
Dreamliner330
My Ride: 330xi
meh, $450 to have the work done for me...could have been worse.
Old 11-29-2010, 01:24 PM   #6
DangerousMind
My Ride: Sierra 1500 SLT
I just give myself a bunch of space and use an impact gun on the upper strut nut. Lay it on the ground with an unmounted tire at the bottom and let it rip. Lowering springs go on like butter compared to oe.
DangerousMind is offline   Reply With Quote
Old 12-21-2010, 07:27 PM   #7
h4nh
My Ride: 05' 325i
Its not so bad after you do it a few times. First time sucks because you're figuring it all out and just get the job done. But 2-3 times you will be able to get it done fast.
h4nh is offline   Reply With Quote
Old 12-21-2010, 07:54 PM   #8
Grande D
My Ride: E36 M3
I'e done it a few times. Did you mke sure to pull your xenon sensor out? It can prevent movement of the control arm. You didn't have the jackstand under the control arm, did you? It is a PITA
Tips:
1) Spray WD-40 on the clamp that the strut housing slides into on the control arm at least an hour before trying to pull the struts.
2) BMW springs are very difficult to compress with home compressors; replace rear shocks, but just remove the front struts. Take it to a shop to swap the springs on machine compressors, it doesn't cost much. Then, DIY reinstall.
Old 12-21-2010, 08:58 PM   #9
franz
My Ride: 03 330i
I was going to suggest this, I have done it but usually wrap it in a blanket first then stuff doesn't go flying everywhere.
franz is offline   Reply With Quote
Old 12-23-2010, 08:27 PM   #10
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
You just have to man up and twist that strut out of the front knuckle. Pull the wheels and the next thing you do is spray penetrating lube down the shaft (that's what she said) of the strut into the knuckle.
Wall mounted spring compressor FTW! It saves time over focking with the crap tool you get from auto zone.
I would have sawed that swaylink in half if I coudn't get it off.
I just tried your theory with my clutch replacement...and I hate your theory. Although it turned out to be true.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
bigjae1976 is online now   Reply With Quote
