My car wont start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 11-28-2010, 11:38 PM   #1
BMDUB 330xi
My Ride: 330xi
My car wont start
Hey every one just thought i would put my problem out there to see if anyone can give me some advice. I have a 02 330xi auto i live in cali its been geetin pretty cold here. The past week or so its been takin me a few trys to get the car started two days ago it took about 5-10 mins and several trys to get it started today it didnt start at all im thinkin maybe its the fuel pump?? I just got it back from the shop i had my thmostat housing replaced along with a sensor and i had a minor oil leak and a power steering leak taken care of now the car wont start.
BMDUB 330xi is offline   Reply With Quote
Old 11-29-2010, 03:52 AM   #2
jhrobert
My Ride: 2003 330xi
I wonder if they left something unplugged like a sensor that would increase the fuel enrichment when it is colder out. I had that problem with a bad sensor on my old 2000 S10 Blazer. I would bring it back to them if the car ran fine before they touched it.
jhrobert is offline   Reply With Quote
Old 11-29-2010, 04:15 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
You didn't say if you were cranking, but since you mentioned fuel pump, I assume you are.
Start by checking your battery voltage. If low, take for 20 min drive on highway and then continue monitoring voltage with cluster test to assess functioning of both bat and alt.
That's one thing that comes to mind after a car has been to shop...that you don't drive it enough to keep battery fully charged, and that while in a shop for a day or two, getting moved around and started repeatedly but not really driven...that it's the battery.
Get a jump start and go from there...and search for 'no start'...millions of threads and other possibilities...but I chose the easiest and most likely first...before considering that mechanics did something wrong or just total random failure of another part.
Doug
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 11-29-2010, 08:08 PM   #4
jhrobert
My Ride: 2003 330xi
I'm working 12 hour days right now. I don't have the time to look up anything for you. Try doing a search for the sensor that is for the cold enrichment valve. You should have one of these on the motor. You can always disconnect a fuel line and turn the key on to test the fuel pump. I suggest running a hose from the disconnected line to an empty gas can to keep from making a big mess or destroying your driveway with gasoline.
Old 11-30-2010, 02:33 AM   #5
mujjuman
My Ride: not an E46
i dont think this is xi specific...
but check your battery like others have said... is your car cranking?
does it crank and fire for a second but shut off a moment later? (are there any vacuum leaks?)
do you hear your fuel pump priming when you turn the key? is your fuel pump relay working? (swap relays)
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 12-02-2010, 01:10 PM   #6
Hero6
My Ride: 330xi
+1 battery if it isn't cranking. Mine had a progressively harder time starting then wouldn't start after a couple weeks last year. Swapped in a new battery and it ran like new.
Hero6 is offline   Reply With Quote
Old 12-02-2010, 01:31 PM   #7
Capt1014
My Ride: 2002 325xi
Same here, it would intermittently not start, then wouldn't start at all, changed the battery..prob solved
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
