E46 Xi Forum
Old 11-29-2010, 09:36 AM   #1
SILVRRONIN
My Ride: 2003 325.xit
Fuel filter replacement
has anyone found ae46 DIY on fuel filter replacement?
SILVRRONIN is offline   Reply With Quote
Old 11-29-2010, 11:04 AM   #2
SamDoe1
My Ride: 4cyl of fury
http://forum.e46fanatics.com/showthread.php?t=265683
Old 11-29-2010, 11:30 AM   #3
EDness
My Ride: 2004 BMW 325xi
Originally Posted by SamDoe1 View Post
yup it's in the DIY section of the forum. I actually just did this last night. The hose clamps are a PITA but if you take your time it's not too bad. I should of jacked up the car higher and place with jack stands instead of putting the car on ramps.
EDness is offline   Reply With Quote
Old 11-29-2010, 03:19 PM   #4
chuckb
My Ride: 2001 330xi
i replaced the 6 hose clamps with new ones and the little pieces of rubber fuel line too.
I just used a cutting wheel and cut the 3 clamps and a razor blade to cut the tube off instead of trying to pull it off.
chuckb is offline   Reply With Quote
Old 11-30-2010, 03:45 AM   #5
mujjuman
My Ride: not an E46
i had this done about a month ago.... the old filter was FILTHY @ 133kmiles
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 11-30-2010, 11:43 AM   #6
SILVRRONIN
Many Thanks for the assistance! The only one I found when I googled it was the e36 one and it referrred me toa pelican parts write up...i was very frustrated! This is my little saturday morning project before getting the Christmas Tree ready this is like my last maintenance project... I just did my oil filter housing Friday( alotta fun!0...Thanks again! Very much appreciated.....
Old 11-30-2010, 11:47 AM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Great DIY!
For anyone who is need of a replacement filter we have them available below...
Best,
Joe
Old 12-03-2010, 09:26 AM   #8
SILVRRONIN
The diy was great..but there is some fine tweking that could be done...
I turned my car several times after i removed the fuse.....
when i removed the foward line it popped in my face- spraying gas ALL OVER!
I had eye protection on-
I had ventallation-
it was very alarming!
I would also note that after I removed the filter the rear line was stil dripping fuel out!
I immediately set up the new fuel filter and hooked it up immediately to the rear line...
Old 01-24-2011, 10:51 AM   #9
bmw_325i_ct
My Ride: 325i
Does autozone or advanceautoparts carry an equivalent fuel hose that attaches to the filter (part #13537563456)? Has anyone used anything but oem fuel hose?
bmw_325i_ct is offline   Reply With Quote
Old 01-24-2011, 01:34 PM   #10
himefrankie
My Ride: 03 330xi
Yes they carry these hoses.
You should be fine using 5/16" (Inner Diameter) Fuel Line Hose for Fuel Injection Systems.
These are rated to a certain PSI, designed to resist internal weakening from fuel blends and external oils/grease/etc., braided for reinforcement and should be covered to resist temperature/weather extremes. These are available in packaged 18" lengths of which you only need about half (cut to measure from your old hoses).
I would replace clamps as well if yours are a little rusty, there are 6 total clamps (2 for each hose) for the fuel filter.
go big or go home.
himefrankie is offline   Reply With Quote
Old 01-25-2011, 09:41 PM   #11
mujjuman
My Ride: not an E46
Originally Posted by ECSTuningJoe View Post
Great DIY!
Best,
Joe
does this have the fuel pressure regulator built in?
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 01-26-2011, 08:34 AM   #12
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Yes they come with built-in fuel pressure regulators.
Old 01-27-2011, 09:08 PM   #13
gurov
My Ride: 2004 325XI Turbo
Send a message via AIM to gurov Send a message via MSN to gurov
i was actually surprised that bmw didn't use a proper fuel hose clamp on these, and these were pain in the ass. not sure if this has been replaced before by previous owners.
i had some 5/16th fuel injection hose laying around, i cut similar strips and used better clamps, not the worm kind:
2014 X1 - m-sport - stock
2004 325xi top mount turbo - megasquirt3 for engine, 5 speed swap. build thread
1994 supra MKIV - single 72mm - bc272 cams - super spec twin plate clutch - aem v2, 1000CC ID, dual denso pump, j&s ultrasafeguard
2004 SE-R SpecV turbo - megasquirt3 j&s ultrasafeguard - SOLD
gurov is offline   Reply With Quote
Old 01-28-2011, 09:29 AM   #14
Ftumminello
My Ride: 2004 325xi
just bought my car not that long ago, anyway to tell if it needs to be changed?
Ftumminello is offline   Reply With Quote
Old 01-28-2011, 10:39 AM   #15
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
if you have over 50kmi.. replace it
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 01-29-2011, 12:09 PM   #16
Pierce1
My Ride: 03 330xi
I just changed mine yesterday. What a PITA! What made it difficult was that even though the car was on all 4 jack stands, I didn't have a lot of room to work. But it's done now and I won't have to do that again for a while. I had also just finnished changing all the drive train fluids.
Pierce1 is offline   Reply With Quote
Old 01-29-2011, 12:33 PM   #17
mujjuman
My Ride: not an E46
i always get mixed reviews... many ppl say its easy as hell but others say its a PITA... for all things BMW lol
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 01-29-2011, 01:17 PM   #18
Pierce1
My Ride: 03 330xi
Mechanicaly speaking it is simple. It's just that the hoses are hard to get loose and room to move your arms and hands to work on it, even though the car is on jack stands is limited.
Old 01-30-2011, 04:44 PM   #19
TX_Bullet
My Ride: 2001 325Xi
I'm with you fairly simple but the clamps just located difficult
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 01-31-2011, 08:33 AM   #20
SILVRRONIN
make sure the presure is out!......experience talking here!
