Old 11-30-2010, 02:13 AM   #1
DriveThruRecFan
My Ride: 1999 BMW 328i
Exclamation Removing radiator fan without special tools?
Does anyone know how to remove the fan without having to buy these special tools?
Any help is appreciated, thanks!
DriveThruRecFan is offline   Reply With Quote
Old 11-30-2010, 06:38 AM   #2
CylonRed
My Ride: '01 E46 330i sport
Are you trying to remove the fan, from the fan housing itself?
CylonRed is offline   Reply With Quote
Old 11-30-2010, 08:31 AM   #3
Sansho
My Ride: 2001 325i
You can't remove the fan without, at a minimum, a 32mm wrench. The wrench has to be just long enough to clear the fan shroud. The one I use, just because it's thin, is sold as a bicycle repair wrench. On mine, I put the wrench on it, tapped it with a hammer to the right and it loosened right up. Where that hasn't worked, others have jury rigged it so the pulley wouldn't turn while using the 32mm wrench. See this picture (borrowed from Beisan Systems excellent vanos repair instructions):
Sansho is offline   Reply With Quote
Old 11-30-2010, 10:14 AM   #4
Spartan E46
My Ride: 2000 323i
I have been successful counter-holding the fan pulley with a very long screwdriver - using the shaft of the screwdriver to hold the pulley by the bolt heads. A little tedious but it works.
Spartan E46 is offline   Reply With Quote
Old 11-30-2010, 10:48 AM   #5
teamdfl
Slow in, slower out
My Ride: 325it
I have done the wrench and hammer trick as well as the wrench and screwdriver trick as described above. At some point, you will come across a fan clutch rusted or otherwise seized onto the water pump that a proper fan holding tool is the only way to break it loose. For what its worth, I never had problems with fan clutches until I started working on E46s so I finally got a water pump tool.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 12-03-2010, 12:51 PM   #6
hogsrul
My Ride: '04 BMW 330i
Would it be a good idea to put some anti-seize on it when re-attaching the fan or would that cause problems?
hogsrul is offline   Reply With Quote
Old 12-03-2010, 02:05 PM   #7
Sansho
My Ride: 2001 325i
I haven't seen any recommendations for anti-seize for that. When I took my fan off at 52K miles, as far as I could tell that was the first time it had been off, and I didn't need the special tool at all. Just tap, tap and it loosened right up.
Old 12-04-2010, 08:37 PM   #8
teamdfl
Slow in, slower out
My Ride: 325it
I always apply antiseize to the water pump threads so the next guy working on the car can remove the fan clutch.
Old 12-10-2010, 08:44 AM   #9
MIRoundel
My Ride: E36\5, E46 325ia
Use regular 32mm wrench when the engine is COLD. The belt holds the fan better when COLD. I've done it about 5 times without any special tool.
MIRoundel is offline   Reply With Quote
Old 12-11-2010, 12:36 PM   #10
swamp_fox
My Ride: e46
If it is stuck, you can use a big punch with a pointed end and line it up on the edge of the nut. Strike it a few times pretty good and it should break free.
swamp_fox is offline   Reply With Quote
