Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 11-30-2010, 11:35 PM   #1
crazyafghanguy
My Ride: E46 M3
e36 high idling p0505
hey fanatics, i need some help to resolve my issues, i have a 98 323is and i have to pass smog but im getting a error code p0505 which is idle control malfunction. im getting bad gas mileage too and i replaced my o2 sensors 2 months ago.
i changed it 2 times from which i bought used. im idling at around 1100-1200 . my research tells me that it could be my thermostat stuck which is causing a high idle because it thinks my car isnt warmed up yet or a coolant temp. sensor. Also im thinking it could be a vacuum leak but i tried the throttle body cleaner but couldnt find any visible leaks.
where would be a common place where vacuum leaks are found? would a vacuum leak cause the code p0505 to show up? i read somewhere that this code will pop up whenever the idle is 100 rpms away from normal but im not sure if this is true. some guy i know tried to erase the p0505 code but it wouldnt erase..... i need helpp e46fanatics!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 12-01-2010, 01:40 PM   #2
crazyafghanguy
My Ride: E46 M3
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-01-2010, 10:39 PM   #3
crazyafghanguy
My Ride: E46 M3
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-02-2010, 10:53 AM   #4
pMak26
My Ride: '99 M3, '07 r6
Step one, clean your ICV.
Step two, you probably have a vac leak somewhere, check intake boot and any line to/from the intake mani while your cleaning the ICV.
Plan to be spontaneous tomorrow.
Base (SuperFlo Dyno: 211whp/199.5wtq)
Then S52 turbo, 442whp
Now LSx
pMak26 is offline   Reply With Quote
Old 12-02-2010, 03:23 PM   #5
crazyafghanguy
My Ride: E46 M3
okay i just got done cleaning my ICV and checking for vacuum leaks. i swapped out my ICV with another ICV i had and cleaned it and it was the same. i checked for cracks in my boots or any place that connects to my intake manifold. i took of my TPS and the rpms jump up 500. i also took out ICV plug and jumped up 500 rpm. i took out the plug out my MAF and the car shut off. i checked the grommets for the ICV and CCV and they were fine and checked the CCV pipe that runs to the valve cover. i checked everything but im still getting a high idle! HELP!!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-03-2010, 03:23 PM   #6
crazyafghanguy
My Ride: E46 M3
i need help!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-04-2010, 04:39 PM   #7
crazyafghanguy
My Ride: E46 M3
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-04-2010, 05:01 PM   #8
pMak26
Car drives 100% fine except the idle? Provide more info
Now LSx
Old 12-04-2010, 06:44 PM   #9
crazyafghanguy
My Ride: E46 M3
yeah everything runs fine. i just have a high idle..... i have tried everything!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-14-2010, 03:09 AM   #10
crazyafghanguy
My Ride: E46 M3
out of all of my research, im guessing its my ccv. when i rev my car in neutral, its takes a while for it to get back to idle. when i take off my oil filler cap there is a vacuum and car begins to idle rough. any other symptoms of a bad ccv?
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-18-2010, 04:10 AM   #11
crazyafghanguy
My Ride: E46 M3
i talked to a mechanic and he said it could be the camshaft sensor, crankshaft sensor, coolant temp sensor, knock sensor or maybe the ccv? i really need help, i have 3 weeks to pass smog
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-18-2010, 04:12 AM   #12
crazyafghanguy
My Ride: E46 M3
and also when i start the car, the car jumps to about 1500 rpm and drops quickly back to 1000 and stays there, could this be the coolant temp sensor or the thermostat?
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-21-2010, 08:37 PM   #13
crazyafghanguy
My Ride: E46 M3
Fixed the problem! it was such an easy problem to fix, there was a adjuster screw for the throttle body which made it open very little taking all the air into it instead of the ICV. i opened the screw so that the TB closes all the way and now it runs perfect! NO check engine light and just passed my smog!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
e36 high idle
