Old 12-01-2010, 09:46 AM   #1
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Automatic: Gears Replaceable?
I have been told that 4th gear ratio is way too much of a drop in RPM (and I agree it is). This got me thinking - can 4th gear be replaced with a better ratio or are two or more gears on the same shaft? I am just really unfamiliar with this automatic.
TIA,
Jim
Jim Murphy is offline   Reply With Quote
Old 12-01-2010, 09:47 AM   #2
McSpeed
My Ride: 2005 ZHP TT Stg 1
TIA,
Jim
I haven't heard of that being done, but the diff gearing can certainly be changed.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-01-2010, 09:59 AM   #3
xixixi
Banned User
My Ride: 01 330x-xi
If he has a auto 330 zhp his gears are already maxed out. For non M. You should have 3.64s 0r 3.62s i forget which (i know one is m3 one is auto zhp). You need a tranny swap. I'd get a 6 speed and leave your rear diff alone. just my 2 cents
Old 12-01-2010, 02:56 PM   #4
Jim Murphy
Thought briefly about changing rear end ratio but that affects the whole RPM/speed range and the only problem is that 4th gear in an automatic has the wrong ratio as it drops the RPM down way too much. Just curious as to what can be changed in this automatic.
Jim
Old 12-01-2010, 03:48 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
You can slap a 3.91 from an X3 in there, too.
But no, that won't specifically help your 4th gear issue.
