E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
Dealer costs for trans and diffs fluid changes
Called the dealer and quoted me a cost of $550 for trans and diffs fluid changes. Crazy or what! Proably gonna do it myself for the cost of the trans filter kit and fluids cost. Got basically the same Cost from an independent BMW service place also. It really needs to be done. I'm in the wrong business
ganicki
2001 325xi 1994 344ic ![]() ![]() if you don't believe go to: http://s88.photobucket.com/albums/k1...cki/?start=all |
#2 |
Is it auto?Just diy and save the bundle of cash.
Filbert
Originally Posted by nawmean? I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit |
#3 |
yeah-- an auto, but what are parts and fluids going to cost-- $100-$125--probably doesn't take a hour of work--I agree, DIY and save a ton o'cash
ganicki
#4 |
Paid $805 for trans and diffs fluid changes and BG Treatment. Had them change the trans filter, cost a little more.
Shift and runs much smoother. |
#5 |
If you have a floor jack and 4 stands there are benefits besides saving $$$. You can see the condition of the fluids. You will need to put ATF in the transfer case too since this fluid seems to boil down to a sludge. Is that in the estimate?
There is a sticker covering the fill plug of the transmission. Once you're past that, draining is straight forward following the many DIYs here.
#6 |
Yeah, because you know the dealer will only take an hour to do the work and charge you for three hours time...think again.
Premium, Sport, & Cold Weather Packages
#7 |
most every shop charges book time.
Unless it goes over. Like for some unforeseen reason like sicking/rusted bolts. Then they make you pay that. I once payed the local chevy stealer $350 in labor to change a god damn dip stick tube because he couldnt get it out. That's why you want top find knowledgeable and experienced mechanics. Sure they do jobs quicker than book time cause they know what they're doing. But you don't have to worry about paying the guy extra $$$$ over book because he works slow or doesnt know the quickest/most efficient way to do things. |
#8 |
Im getting all my drivetrain fluids flushed tomorrow for ~$180 @ a BMW mechanic.
Sent from my SAMSUNG-SGH-I897 using BimmerApp |
#9 |
We have a complete section devoted to the E46 Xi drive train fluids available
below... Click HERE for more information. ![]() Click HERE for more information. ![]() Please let us know if you have any questions! Feel free to shoot me a PM or email. Best, Joe
![]() Have questions? Need answers? Live Chat us! 8:30am to 12:00am Midnight EST sales@ecstuning.com | customerservice@ecstuning.com Customer Service Hours: 8:00am - 8:00pm EST Sales Team Hours: 8:00am - 11:00pm EST 800.924.5172 |
#10 |
diferentail fluids are easy..transmission was a doosey, filling the fluid and starting the car to insert more fluid and insert the plug next to the exhaust was a little brutal. But I saved about $300 doing it myself witha buddy of mine. exactly what everybody says STEALERSHIP!
#11 | |
#12 |
Biggest surprise for me when doing the trans fluid was that you have to remove the driveshaft from the transfer case to the front diff. Requires an inverse torx socket which I had to run out and get at Sears. Also you need to run the car in gear with all 4 wheels off the ground and you on a creeper checking the fluid level, SCARY! but definately worth the trouble.
#13 |
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
1st. of all, better way is you use 12 cement block (construction, Home depot) and 4 pieces of 6" x 3" x 12 feet long to make the ramp.
I did , it safe, easy, removable when done, cheaper than small steel ramp. The car will up about 10 inches, level, easy to craw under ( buy the stroller too) . Do not need to remove drive shaft as CONV440 needed. Do not need to buy the pump to pump fluid in, use 1/2 " plastic tube, then drill the hole 1/2 " on the cap of jug ( any jug 4-5 quarts ) put the tube in to bottom, put the jug on the chair about 3 feet high, press by 2 hands to the sides of jug, fluid will flows in to tranny, then open the cap to let air in, it take 10 minutes for 5 quarts go in . You better buy 11 quarts to flush out ALL old fluid. It could take you 3 hours to do the job, but it worthy . Differentials & transfer case is very easy, But you need 14mm Hex/allen key bit . |
#14 | |
#15 |
I don't know how you can access the fill plug with the driveshaft in place, there is no way to get a hex socket on the thing or add fluid back in.
+1 on the cinder block thing, too many sad stories about what happens when they fail suddenly.
![]() Last edited by conv440; 12-08-2010 at 09:02 PM. |
#16 | |
I used a pump though so i didn't need much room fill it with fluid. |
#17 |
tranny fluid
#18 | |
tranny fluid
WHOA NELLIE! cynder blocks! whitch were designed for cementing ona block pattern for asay..a small fire pit or the foundation of a tool shed! THATS A HUUUGE NO NO! they will give and a two ton automobile on your head and chest..... |
#19 |
Wait, why don't you guys with an auto tranny just measure how much fluid comes out, and then refill with the same amount? Just wondering.
#20 |
Drain & Fill is easy to do. What about replacing the old filter in the tranny. With that many miles the thing has be clogged up quite a bit and probably reduces the flow of fluid. I definitely had mine replaced. Worth it. After market is $50 and OEM is about $80?
Oil filter is changed at every oil change why not the tranny filter??? |
