Old 12-01-2010, 12:04 PM   #1
KohbraxE46
My Ride: E46 328i
Engine ticking after over heat !!!!!!
Hi I drive a 328i sedan
And I had over heating problems when I first go the car ( it's a salvage) and the work they did was a mess
Any ways all problems fixed
But one night driving home my engine was overheating and I pushed it and made it home..
But the next day I noticed a ticking noise from my engine
I'm sure I blew something
My car runs and drives awesome now . It just has that annoying ticking!!!
I have no lack in power
Any ideas how I cam fix it or what it is ???
Please help meeee
KohbraxE46 is offline   Reply With Quote
Old 12-06-2010, 03:53 AM   #2
sjermyn
My Ride: 330ci
Hmmm....I've seen this problem before, at least I've experienced the ticking noise in an engine that had been overheated. I hope this is not the cause, but...what had happened was the big end bearings had started to delaminate allowing the piston on one cylinder to touch the top of the head. That was the ticking noise. If not attended to urgently the conrod breaks or goes out through the side of the block.
As I said, I hope this is not your issue.
sjermyn is offline   Reply With Quote
Old 12-06-2010, 12:50 PM   #3
KohbraxE46
My Ride: E46 328i
Wow that seems bad
I have put at least 3-5000 miles on the engine since, and it drives great
How do I check if that's really the issue?
How can it be repaired ?
Old 12-07-2010, 01:45 AM   #4
sjermyn
My Ride: 330ci
If you have done over 3,000 kms since the overheat it is very unlikely that it is the big ends ticking. What you can do however, is do an oil change and strain the oil through a pair of pantyhose and look for metal filings. If none, no problem with the engine internals.
After haveing done the above the next thing it could be is the exhaust manifold with a slight leak. Another thing that often happens when they have been overheated, so start to look there. A long screwdriver with your ear at one end will help to locate it.
Let us know how you go with the above checks?
Steve
Old 12-08-2010, 10:25 AM   #5
KohbraxE46
My Ride: E46 328i
Steve
Thats a good idea I'm going to do an oil change when I get back from my holiday break 3 weeks
So I'll check for that
I think it could be the exhaust manifold because the ticking is stringer when you get your ear to the bottom almost under the car behind the engine.
Also I forgot to mention after the over heating I turned on my car the next day and it blew white smoke but only for about 3 seconds. As if it had cleaned out the exhaust or something.
Ever since then I have had the ticking. But never again any white or any kind of smoke it runs clean.
So any ideas ?
Thanks for helping I'll keep you posted
Old 12-11-2010, 12:26 AM   #6
Recon2005
My Ride: VF-E 328Ci & 325 E90
Are you sure the tick isn't a hydraulic lifter? Maybe the tick wasn't as prevalent prior to overheating.
Vortech // Magnaflow // Hotchkis // H&R
Originally Posted by Forcefed M3 View Post
Could not agree more. I enjoyed my vf kit to the day I took it off. VF best s/c out there. Period
Recon2005 is offline   Reply With Quote
Old 12-11-2010, 10:04 AM   #7
KohbraxE46
My Ride: E46 328i
That's what my GF's dad says ( he's a fed ex mechanic)
He says it could well be the lifters and I agree
Cause of his many years of experience
My new question is
How can I fix that?
Old 12-11-2010, 11:03 PM   #8
Recon2005
Have to install new hydraulic lifters. No easy fix, but for the most part it's not really a big issue. Run it as is, make sure you are using the correct BMW approved oil and that your oil is always full. You won't harm anything; just have to endure the noise.
Sent from my DROID2 using BimmerApp
Old 12-11-2010, 11:42 PM   #9
KohbraxE46
My Ride: E46 328i
Yea that's what he told me. And that's what I'm doing now keeping up with my oil.
That ticking is so annoying
What's the diy
What males it hard? Do you have to pull your engine out ?
Is it worth it ?
Old 12-12-2010, 11:43 AM   #10
TrickTizzle
My Ride: 325i
POst a video, could be VANOS seals.
Old 12-13-2010, 02:47 PM   #11
KohbraxE46
My Ride: E46 328i
Will do good idea
