E46 Xi Forum
Old 12-02-2010, 12:42 AM   #1
sjh2500
My Ride: 2001 330xi
Arrow springs? Wheels? suspension?
hey guys, i was thinking about getting new wheels/ suspension/ springs for my 01 330xi. The reason is because it is all wheel drive, the suspension/springs makes it sits a little higher than other bmws. i was just wondering how much i should lower it/ which springs i shud get to make it more normal or lower than normally. And with which wheels. Also im not trying to break the bank here.
sjh2500 is online now Report Post Edit/Delete Message
sjh2500 is offline   Reply With Quote
Old 12-02-2010, 07:19 AM   #2
ATF
My Ride: plows snow.
Uhhh what's your budget...?
Nick | BMWCCA 403399 | flickr
ATF is offline   Reply With Quote
Old 12-02-2010, 09:50 AM   #3
SamDoe1
My Ride: 4cyl of fury
REALLY??? NO way!
To sum up all the other threads on this:
If you want comfort + performance - a little lowering = Eibach springs with Koni shocks/struts.
If you want performance + lowering - comfort = H&R springs with Bilstein shocks/struts
If you have money, just do coil overs.
No matter what you decide, get an alignment after you're done and you might as well replace all the bushings while you're in there.
Don't slam it, it will do quite a number on your front drive train.
Wheels are up to you, don't go staggered as it will give you more understeer.
Good luck.
Old 12-02-2010, 02:36 PM   #4
Capt1014
My Ride: 2002 325xi
I have Bilstein HD shocks and struts, with H&R springs, dropped it about 1 to 1.5 inches. Some people like Eibrach springs if you drive on alot of bumpy roads.
All in all I spent less than 500 for the suspension. Check Bavauto.com for the shocks and struts. Bunch of folks on the forum have springs.
I'm also planning on getting 17" rims, 18" will fit but I like the 17's a bit better
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 12-03-2010, 01:12 AM   #5
Dreamliner330
My Ride: 330xi
I've got a set of H&R Sport springs from my e46 xi sedan, you can see the ride height in my sig.
I have only driven ~15,000 miles on these springs. Send me a PM if you'd like them, I'll set you up!
Dreamliner330 is offline   Reply With Quote
Old 12-03-2010, 08:13 AM   #6
Capt1014
My Ride: 2002 325xi
What rims are those on your ride?
Old 12-03-2010, 09:00 AM   #7
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
He's got M6 Reps on there.
Im sittin on Bilstein Sport Shocks with H&R Sport springs, the drop was around 2". That left a 2 finger gap front and rear with 18in rims on.
If you still want a comfy ride, go with koni yellow w/ Eibach or the dinan stage 1. The drop will not be as much as what i got but it wont be as harsh. I personally dont think the ride is harsh, but others on here want their cars to drive like Cadillacs.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 12-03-2010, 11:12 PM   #8
chaso
My Ride: 2001 330xi
+1.
In regards to this, I want the stiffest setup I can find. FK konigsports or the HR sport cup kit are possible candidates.
chaso is offline   Reply With Quote
