Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 12-02-2010, 11:21 PM   #1
blackcar
My Ride: 330
spacers question
Hello,
I am considering to have 225 all around tires so that I can rotate. Also, I will use 15 front/ 25-30 rear (to make up for the thinner tires and for the flush look). I saw on another thread that 15 works for the front. Does it work for this? do you think 15 for the front is too much for this situation?
I was wondering if anyone foresee any problems or additional stress issue.
This will be on sport springs 2001 330ci
blackcar is offline   Reply With Quote
Old 12-03-2010, 12:57 AM   #2
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
It's hard to say without knowing the specs for the wheels that you'll be using.
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 12-03-2010, 01:00 AM   #3
M00P
Location: El Pueblo Nuestra Senora la Reina de los Angeles de Porciuncula
My Ride: e46 m3, e36 sedan
Put the tires on. Measure the gaps. Order spacers.
M00P is offline   Reply With Quote
Old 12-03-2010, 10:12 AM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The best way to understand which size spacer you need, is to simply measure from the top outside edge of your tire to the inner lip of you fender. This will give you the best idea on how much size you have to work with, and to decide on how much your wheels need spaced.
Once you know that let us know and I will be able to recommend which size will be the best fit for your application.
Here is a diagram that might help as well.
We have a complete line of spacers available specifically for your vehicle below...
Click HERE to order or for more information.
Best,
Joe
800.924.5172
Old 12-03-2010, 11:38 AM   #5
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Definitely recommend measuring first to make sure. This video will help.
