E46 Xi Forum
Old 12-03-2010, 02:19 PM   #1
Chadrobb4
My Ride: 2003 BMW 325xi
03 325xi Idle Surge
Hi all, I have an 03 325xi that is surging when coming to a stop/idle. Right around 1k RPM it will surge quickly 500RPM and settle out. I know there are a few threads out there on this topic.
Ill be checking codes and look for leaks, but most of that has already been changed and no check engine lights.
One thing I do need to do is replace the thermostat as it threw a P0128 (I know I just said it hasnt had any check engine lights, hasnt had any new check engine lights) and the engine is running very cold with the winter temps coming in.
Is the most likely cause related to the fact it needs a thermostat? Also thinking about changing the VANOS seals while I have the mechanical fan out.
Any info is greatly appreciated.
Chadrobb4 is offline   Reply With Quote
Old 12-03-2010, 02:34 PM   #2
Capt1014
My Ride: 2002 325xi
I have the same thing happening to mine, but it's always been like that since I bought it a year ago (02 325XI)
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 12-03-2010, 02:49 PM   #3
Chadrobb4
Its quite annoying! I fix one thing, another pops up.
Old 12-03-2010, 03:38 PM   #4
SamDoe1
My Ride: 4cyl of fury
If you have to change the t-stat then just do it and see what happens. Other things to look at would be the camshaft position sensor and/or the coolant temperature sensor.
Old 12-09-2010, 04:53 PM   #5
Capt1014
My Ride: 2002 325xi
Coolant temp sensor can make the idle surge?
Old 12-09-2010, 05:29 PM   #6
SamDoe1
I would think so, if the coolant is cold the engine will idle higher than if the coolant is hot. Turn your car on on a cold day and it will idle quite a bit higher than after you drive it for 20 minutes. Any variation in this signal could vary the idle speed of the engine.
Old 12-09-2010, 05:40 PM   #7
E-rock
My Ride: '01 330xi
My previous car had an idle surge in cold weather. Very annoying. It ended up being a temp sensor.
"So when you go for a drive, remember to leave your murderous anger where it belongs - at home."
E-rock is offline   Reply With Quote
Old 12-09-2010, 09:26 PM   #8
Kubica
My Ride: 2003 325xi
It's probably the DISA. Search for the video on here that shows the difference between a broken and new DISA valve.
Old 12-09-2010, 10:40 PM   #9
mp333
My Ride: 2003 325XI
Try disconnecting the DISA, see if there's any change. Also is the ICV clean?
mp333 is offline   Reply With Quote
Old 12-10-2010, 09:43 AM   #10
E-rock
My Ride: '01 330xi
I've never known or experienced a dirty ICV to cause the rise and fall the OP described. Rough idle, yes, but not a rhythmic, surging idle. Couldn't hurt to clean the ICV if it hasn't been done in the past year or two but my guess is a temp sensor has gone bad, or worse, coolant isn't coming into contact with the sensor.
Old 12-10-2010, 02:51 PM   #11
Kubica
My Ride: 2003 325xi
Nah, it's the DISA.
Old 12-10-2010, 03:38 PM   #12
Capt1014
My Ride: 2002 325xi
Originally Posted by kubica View Post
nah, it's the disa.
disa?
Old 12-10-2010, 03:55 PM   #13
nickchuck
My Ride: 325xi (Topaz)
Probably the DISA Valve. http://www.ecstuning.com/Search/11617544806/ES25794/ You can disconnect this on your own very easilly. If it flaps open and closed (no spring tension) it's broken.
If not check the coding of your computer. I had mine updated with the newest software ($129 at the dealer) and all my idling issues dissapeared. This may be a good idea if you haven't done it recently anyway.
nickchuck is offline   Reply With Quote
Old 12-10-2010, 05:44 PM   #14
Rickna
My Ride: '01 330xi - '09 IS-F
disa?
Air Adjustment Unit
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
