Old 12-05-2010, 01:10 PM   #1
Rewind325i
My Ride: 2001 325i
Grass stuck between tire and rim losing air
Last night a animal ran out in front of my car and i swerved to miss it because it was so close. Their were sprinklers on and my car slid and did a 180 onto some grass, later upon closer inspection their is a ton of grass stuck between my rim and tire about the width of my pinky. I looked up and havent seen anything like this, do i have to take it to a tire shop?
Rewind325i is offline   Reply With Quote
Old 12-05-2010, 01:15 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I never heard of it, but I think that when you did the 180 the tire dislodged off the rim for a bit and that's where the grass got in with dirt.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-05-2010, 01:24 PM   #3
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
Is this even a question? The fact that you're loosing air pressure should be a sign to you to get it fixed.
You may have punctured the tire, it's pretty rare for tires to un-bead itself from the rim. I'm not saying impossible but really rare. For your tire to un-bead itself your sidewalls must be pretty soft and your tire really under inflated.
To make sure where the leak is actually coming from, do a test with the wheel in question with water to see where the air bubbles form.
MrMotorwerk is offline   Reply With Quote
Old 12-05-2010, 01:39 PM   #4
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
pics...
delmarco is offline   Reply With Quote
Old 12-05-2010, 01:45 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 12-05-2010, 01:48 PM   #6
delmarco
lmao!!!!!
Old 12-05-2010, 02:12 PM   #7
kpeng
Banned User
My Ride: E46 330 and E30 325
You better go quickly. The grass wedged in there will not be able to take the high speed of your wheels spinning. It will catch fire, and your car will explode before you know it. This is a matter of life and death.
kpeng is offline   Reply With Quote
Old 12-05-2010, 02:20 PM   #8
slammin_330
My Ride: is no ZHP.
^^Don't drive near any elementary schools or wild life refuges until you fix this!
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
Old 12-05-2010, 02:58 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
Yes, take it to a tire shop.
Old 12-05-2010, 06:20 PM   #10
BoogetyBoogety
My Ride: 2010 SL550
Use this handy-dandy flowchart to fix any problem with any car:
Does an item look or work as it did when it left the factory?
Yes - Leave it alone.
No - Fix it.
Can you fix it yourself?
Yes - Fix it.
No - Get it fixed by someone who knows how to fix it.
BoogetyBoogety is offline   Reply With Quote
Old 12-05-2010, 06:21 PM   #11
RogueStatus37
My Ride: '04 330ci
Hese not kidding. This happened to a buddy of mine. Luckily he was driving right next to a community pool so he drove into it and put the fire out.
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 12-06-2010, 07:14 AM   #12
Rewind325i
My Ride: 2001 325i
thanks
Thanks guys i had no idea what to do. Now with your help i know that it shouldnt be fixed, i should probly just keep driving it until my car catches fire and explodes
Old 12-06-2010, 07:16 AM   #13
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
take it to el cheapo tire shop, why are you still here? Just go fix it.
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 12-06-2010, 07:32 AM   #14
NOVAbimmer
My Ride: E60M
1. Does an item look or work as it did when it left the factory?
No - Fix it.
2. Can you fix it yourself?
Yes - Fix it. (continue to question 3)
No - Get it fixed by someone who knows how to fix it. (continue to question 4)
3. Did the fix work?
Yes - don't repeat whatever you did to cause the problem
No - return to step 1
4. Can you afford the fix?
Yes - Pay to have it fixed (continue to question 3)
No - Sell your car.
fixed
NOVAbimmer is offline   Reply With Quote
Old 12-06-2010, 07:33 AM   #15
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
get out your mower and cut the lawn
/_________\
O==[][]==O
Old 12-06-2010, 07:39 AM   #16
NOVAbimmer
My Ride: E60M
sounds like he just needs to do some more slides across the lawn and he'll be good, no mower needed. Sounds like a lot more fun, too.
Old 12-06-2010, 07:42 AM   #17
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Ran into a [sic] animal?
You swerved to save a squirrel? I know that's what it was...coz if a dog or cat...a cow, deer, or bear, we would have heard about it. That you don't want to tell us is good though.
From this, I know that you know you should've just kept going...and you should have. I'm sorry, but some things you just have to have 'programmed' in your head when driving.
I had a raccoon commit suicide by e36...cost me $600...and it would have been more if my bumpers needed paint, but they came from factory with the gray matte finish that was OE for my '92 (RIP).
Anyway, you just need to have that as an instinctive reaction...there are some things you just need to be prepared for all the time on the road...low odds things. But srs, since this was such a reactive move of yours, consider yourself lucky that you didn't slam into a tree, over ravine, tumbling end over end and bursting into flames like in the movies.
Be prepared...you just have to run over little animals...even really cute little ones.
Rinse undersides afterwards.
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 12-06-2010, 10:45 AM   #18
sharpx
My Ride: E46 330i
el cheapo should not touch our wheels...
Shops w/ Roadforce balancer FTW
sharpx is offline   Reply With Quote
grass, help me!, swerve, tire, wow
