E46 Xi Forum
Old 12-07-2010, 09:53 AM   #1
RobNH
My Ride: 2008 335xi Coupe
2004 330xi Shaking Violently
I have a 2004 330xi with 66,000 miles on it - 6-speed manual. Lately, I've noticed that after the car heats up, it starts to shake violently when you accelerate. You can definitely feel it through the steering wheel.
Take your foot off the gas, or give it just a light amount of gas - it's fine. It's even more noticeable when going up a hill.
Does anyone have any ideas what this might be?
RobNH is offline   Reply With Quote
Old 12-07-2010, 09:58 AM   #2
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
Have gotten the front end checked out?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 12-07-2010, 10:02 AM   #3
RobNH
Not yet. I'm going to be making an appointment for it shortly. I'm guessing it's the front cross member bushings because I was told they were starting to show signs of cracking.
Old 12-07-2010, 10:10 AM   #4
GCoop
My Ride: '04 325xi
"Ill take XI drivetrain for $2000 please Alex....."
"When worn and/or deviod of grease these can contribute to a significant shudder on acceleration...."
"What are the inner CV joints?"
"Correct for $2000"
My money is on this. Let us know what they find.
GCoop is offline   Reply With Quote
Old 12-09-2010, 04:55 PM   #5
RobNH
Front control arm bushings were totally shot. Just got the car back from the shop.
$335.00 to replace the bushings, check the alignment and take it for a 20 mile road test.
Car drives great again.
Old 12-09-2010, 05:02 PM   #6
SamDoe1
My Ride: 4cyl of fury
"Correct for $2000"
Oh I'm sorry, the judges reviewed the tape and your answer was actually incorrect. We are going to have to deduct $4000 from your score.
Old 12-09-2010, 05:04 PM   #7
bombguy
bombguy's Avatar
My Ride: 2004 M3
Hmmm. did they check out the inner CV boots like everyone mentioned?
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 12-09-2010, 07:18 PM   #8
GCoop
My Ride: '04 325xi
If what was posted is actually true he will be the first XI person to EVER have suffered a vibration/shudder on acceleration that was fixed by CABs........
Either that or the original symptom was not described accurately.
As far as Im concerned the jury is still out. I would like to see a longer sustained period at highway speeds before saying he is out of the woods. Mine and many others symptoms never started to show up until 45 min to an hour at highway speeds. I wonder if the worn CABs possibly magnify the issue.
In any case OP..... Please report back to this post later on to let us know if the CABs were truely the end of it. As I said I have never seen another XI person solve this issue with CABs. It would be nice to know.
Old 12-09-2010, 08:16 PM   #9
RobNH
Yep, they checked out the entire driveline and suspension system. Everything was ok, except the front cross member bushings.
Old 12-09-2010, 08:17 PM   #10
RobNH
I played around with the car tonight and no shudder what so ever. I'll be taking it to work tomorrow and that will be the final test.
Old 12-09-2010, 08:18 PM   #11
RobNH
Also.....I can tell you that going over bumps, etc., the front suspension felt loose. Not anymore. The car is tighter than a virgin now. It feels just like the day I bought it from the dealer.
Old 12-10-2010, 03:47 AM   #12
My white xi
My Ride: 2004 330xi
Nice now you get to loose her up again...in a few 100.000 klm you will have to start again..for now enjoy..
My white xi is offline   Reply With Quote
Old 12-10-2010, 03:51 AM   #13
Dreamliner330
My Ride: 330xi
Man, my car was shaking violently the other day too...but it was frozen snow in the wheels from the parking lot drifting in the last snowstorm...
When my CV boots started cracking, my mechanic charged me $350 to remove all 4 front boots, clean, new re-boot and grease. Way cheaper than new Axles.
Dreamliner330 is online now   Reply With Quote
Old 12-10-2010, 12:19 PM   #14
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
ive been putting it off too long.. my driver side axle needs to be replaced im afraid.. i also have some leak up front that i cant trace to a source yet. im betting diff or transfer case as i never had a leak until i had my mechanic flush and fill them.. hopefully its just the need for a new fill/drain plug washer as he probably reused the old ones.
could a wheel bearing cause this vibration as well? the car seems to make a noise with the vibration as well. it does however come and go which is weird..
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 12-10-2010, 04:32 PM   #15
Rickna
My Ride: '01 330xi - '09 IS-F
The transfer case holds very little oil (Bentley manual says 0.16 qt), if it's leaking don't put it off. Jack up the car and try to rock the suspect wheel, if there is play it's the wheel bearing. I had similar vibration symptoms and it was the FCAB's.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-11-2010, 08:04 AM   #16
wdeerfield
wdeerfield's Avatar
I have an appointment with my indy this week to take care of it all. I dont think its my fcabs as i have powerflex and they look like the day they went in.
Old 12-11-2010, 08:37 PM   #17
mcopenha
My Ride: '01 325xi, '73 2002
btw, i just posted a new front axle DIY here: http://forum.e46fanatics.com/showthr...161&highlight=
Same symptoms as OP, but it was clearly my axles. Boots were torn, grease everywhere.
mcopenha is offline   Reply With Quote
Old 12-13-2010, 03:37 PM   #18
bdecker
My Ride: 04 330xi
I did my CV boots at around 100k but our cars are the same age so time may be as much of a factor as mileage. Watch for any sign of grease in your front wheels and if you see it don't delay. The bushing and control arms were done about 10k before the CV boots in my case.
bdecker is offline   Reply With Quote
Old 12-15-2010, 04:14 PM   #19
wdeerfield
wdeerfield's Avatar
turns out i had a seized caliper on the passenger side front...
