Sponsored by BimmerWorld
Old 12-07-2010, 09:25 PM   #1
secono330ci
My Ride: 04' 330ci/15' A3 TDI
Need Advice: Rear chassis sits much lower on pass. side (Coilovers)
I've been meaning to ask this question for a while. My car sits over an inch lower on the rear passenger side when my spring adjusters are set to the same height. In order to make the rear of the car evenly stanced, I need to set the passenger side adjuster to almost the highest collar setting, while the drivers side is where I want it at almost the lowest setting. What could be the problem? I know that many times one side will tend to sit a bit lower, but over an inch different doesn't seem right. Nothing to do with the springs or adjusters, I've measure both and they're equal.
Oh...and the "$300 here, $600 there" scenario will turn into "$3000 here, $6000 there". I've had an enourmous amount of labor put into my car. (Luckily the majority of it was done by myself) Also, I've spent over $5k on my tool set since I started my project. You've been warned...
secono330ci is offline   Reply With Quote
Old 12-07-2010, 09:27 PM   #2
franz
My Ride: 03 330i
measure on different surfaces to see if it's the road. Keep front wheels straight. The battery is back there if you have weak springs that may be the difference.
franz is offline   Reply With Quote
Old 12-07-2010, 09:36 PM   #3
secono330ci
I've tried that many times unfortunately. I also originally thought it might be the battery but I already have a lighter battery there. Gotta also keep in mind that the exhaust is on the other side to balance it out.
Old 12-07-2010, 10:00 PM   #4
w0w
My Ride: '02 M3 Vert
haha i feel u man! i actually had my passenger side set at the highest setting while the driver side was at the lowest setting and they evened out perfectly. my next test is gonna be removing both adjusters and seeing what happens.
daron
w0w is offline   Reply With Quote
Old 12-07-2010, 10:03 PM   #5
turbo_f22_pilot
My Ride: 2 pedals - 2 paddles
Alright, question and answer time!
Are the correct springs in the proper places and installed correctly?
Does your setup have compression, rebound, damping, and/or preload settings?
Swap the springs in the rear, does the issue move with the springs?
In order to finish FIRST, you MUST first FINISH !
Joy is future proof
Get your "M" on . . .
Reading is FundaM3ntal
CAR:
2003 TIAG Coupe / Blk Interior / SMG / HK Premium
MODS:
EU-CSL Coded / Macht Schnell intake / OEM CSL Wheels / OEM CSL Diffuser / Dinan Exhaust
Full LED Conversion / HID fog / Aurora AE / RE RTAB FCAB
BMWCCA NCC
turbo_f22_pilot is offline   Reply With Quote
Old 12-07-2010, 10:05 PM   #6
secono330ci
Yup that's how mine is! Funny thing is when I tested the oem size springs they provided without adjusters, everything sat even at stock height
Old 12-07-2010, 10:08 PM   #7
secono330ci
Everything is perfect, I've re checked many times including swapping sides. The Coilovers are compression adjustable and incorporate adjustable shock bodies, all are set evenly.
Old 12-07-2010, 10:34 PM   #8
w0w
ya man i dont know what to tell u, im in the same boat. im pretty sure there's a bunch of us with the same issue with different setups as well
daron
Old 12-10-2010, 03:34 PM   #9
secono330ci
Damn anyone else care to chime in?
Old 12-10-2010, 03:38 PM   #10
Dreamliner330
My Ride: 330xi
Fat lady friends?
Dreamliner330 is offline   Reply With Quote
