E46 Xi Forum
Old 12-08-2010, 03:01 PM   #1
conv440
My Ride: 05 M3 Vert 04 330xi
60/40 Power Split
Maybe a stupid question but I've read that our XI AWD system transfers 60% power to the rear wheels and 40% power to the front. Ok fine, but how does this work? The front and rear wheels turn at the same speed. If you gear the fronts down through the transfer case to reduce the power won't that also make them turn at a slower speed? Maybe it's the definition of the word 'power' that is throwing me off. Can anyone enlighten me?
conv440 is offline   Reply With Quote
Old 12-08-2010, 03:20 PM   #2
Capt1014
My Ride: 2002 325xi
The Computer
Mods, Bilstein HD Struts & Shocks, H&R Springs, F1 Racing Stage 2 Clutch & Chromoly Ltw Flywheel...more to come.
Overkill is an often underrated state of achivement!
Capt1014 is offline   Reply With Quote
Old 12-08-2010, 03:21 PM   #3
ProchaineStation
My Ride: 03 Corolla
Send a message via MSN to ProchaineStation
usually all AWD systems are like that, even audi
Next Stop: ProchaineStation™
www.youtube.com/AntoDamicoShow
ProchaineStation is offline   Reply With Quote
Old 12-08-2010, 03:28 PM   #4
conv440
Say I have an electric vehicle with motors for the front and rear wheels. I can put a 40 HP motor on the front wheels and a 60 HP motor on the rears. They will have different horsepower at any given speed but both motors are turning at the same RPMs. How do you do that with a single engine and a transfer case?
Old 12-08-2010, 03:42 PM   #5
SamDoe1
My Ride: 4cyl of fury
Originally Posted by Capt1014 View Post
The Computer
Computer doesn't touch the transfer case.
It works through a planetary gearing system. Engine power comes out of the transmission and into the transfer case. Engine power goes to the front drive shaft through the sun gear of the planetary set the ring gear provides power to the rear wheels. The whole process is worked out so that the wheels turn at the same speed, it's all in how the gearing is set up in the system.
Google planetary gears for more info.
Old 12-08-2010, 05:16 PM   #6
dephantn
Location: Toronto Canada- Family's EX :745i & X5 - 525i-323i
My Ride: 740iL-325xi
Our E46 xi use old style transfer case with planetary gear as SamDoe1 said to make Front & rear wheel same speed but 40/60 torque (all mechanical)
The new Xi & X5 use clutch and chain in transfer case , the clutch control by DTS/ABS to run the motor to press the clutch, so the torque can transfer to front or rear when it need, to 100 % .
The X5 even has the clutch ( option ) between two rear wheels to control & can sends the torque 100% to either rear wheel, all makes Bimmer xi the best slip handling.
It can go up hill with one side good road & other side icy , stop and go again.
dephantn is offline   Reply With Quote
Old 12-08-2010, 05:18 PM   #7
GCoop
My Ride: '04 325xi
62/38
I'm a stickler.
GCoop is offline   Reply With Quote
Old 12-09-2010, 08:17 AM   #8
Capt1014
My Ride: 2002 325xi
Oh.
Old 12-09-2010, 10:07 AM   #9
Pierce1
My Ride: 03 330xi
So basically the newer XDrive is an electronic computer controlled version of the ix viscous coupled drive train.
Pierce1 is offline   Reply With Quote
Old 12-09-2010, 10:40 AM   #10
SamDoe1
Yes, but only to control torque split front and rear. Unlike what was said before, the xdrive system only does front to back. Any left to right slippage is still dealt with by the DSC system. There are no clutches in the differentials, both of them are normal open diffs with the DSC braking the slipping wheel to send power to the other wheel. The center diff does have a clutch system which sends power front or back as needed and is computer controlled.
Old 12-09-2010, 11:18 AM   #11
latitude39
My Ride: 2002 325xi (163k)
Diagram for 60/40 power split
I have done some research into the New Venture 124 transfer case that is on our e46 (2001-2005 325xi and 330xi) models. I hope this helps. Please note that I am not an authority on this--just an interested enthusiast.
I have asked the same question: what is going on in the transfer case to make the 60/40 split happen? I've attached two diagrams I found. The first diagram shows the planetary gears (ring gear, the 3 planet gears, and the sun gear). I summarized my understanding, in terms of input from the transmission and outputs to the front and rear driveshafts:
• Input from the transmission turns the planetary carrier—the housing that holds the 3 planetary gears together as a unit. The small planetary gears in the carrier are meshed with both the larger sun gear, and the surrounding ring gear.
• Output to the rear driveshaft comes directly from the ring gear, which is driven by the planetary gears.
• Output to the front driveshaft comes indirectly from the sun gear, which is driven by the planetary gears. The sun gear then turns the transfer gear(not shown on this diagram), which, in turn, turns the output gear that is connected to the front axle.
The second diagram shows a cutaway view of the TC with the planetary unit at the top, the "transfer gear" in the middle, which turns the front driveshaft.
Name:	BMW 325xi transfer case planetary torque split.jpg
ID:	386394   Click image for larger version
Name:	BMW 325xi transfer case cutaway.jpg
latitude39 is offline   Reply With Quote
Old 12-09-2010, 10:40 PM   #12
pjaneiro
My Ride: 2004 330IX
Yes, But Audi is the reverse
68% front
32% rear
Bleh !!!
pjaneiro is offline   Reply With Quote
Old 12-13-2010, 01:35 PM   #13
welcher330xi
My Ride: 2001 330xi
Audi used to be 50/50 until slippage but is now 40/60 (front/rear).
Excluding Haldex equipped models
welcher330xi is offline   Reply With Quote
