Bilstein Sport vs. HD (Direct from Bilstein) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-08-2010, 03:44 PM   #1
Messe46
My Ride: 325xi ZSP - ONRLS
Send a message via AIM to Messe46
Arrow Bilstein Sport vs. HD (Direct from Bilstein)
Hey Guys,
So it's time for my rear shocks to be replaced and I was searching around for info between the 2 shocks list above (Sport and HD, for those who can't/don't read everything ). All the stuff I came across in the "xi section" did not help answer my question: "what's the real difference(s) between the 2?"
That's when I finally called up Bilstein directly, down in Mooresville, NC. The woman I spoke to sounded very knowledgeable, confident, and timely in her responses (did not have to put me hold on, etc. after I asked my questions).
Here's what I came up with:
The Sports and HDs have the exact same internals (same valving, compression ratios, rebound, etc.). The difference in the 2 is the height of the outer tube, which is to accommodate different spring heights. She assured me that the 2 shocks will have similar ride qualities, but the sport will be slightly stiffer. This is not because of internals, but rather the shorter tube length makes for the ride to be slightly stiffer since there is less room form the fluid to move (there's probably more head-loss and other factors from having more area to move (I'll let you know when I take compressible flow next semester )).
As for ride height (important for me and others in areas with snow (Vermont for me)), the car will have the same height whether you have the Sports or HDs (ride height will depend on the springs you use).
**Read this if you read nothing else** She also told me that if you have any lowering springs (H&R, Eibach, etc) with the HD shocks and the shocks blow-out, YOUR WARRANTY IS VOID!!! I don't know about you, but that helped me make up my mind on which ones to get.
Summary:
-Same performance
-Same internals (valving, etc)
-Different length tubes (shorter tube makes slightly stiffer ride, but both rides will be similar)
-WARRANTY BECOMES VOID for HDs with lowering springs (if/when they blow)
I hope that helps anyone else out if they were in the same boat as me.
Disclaimer: this is based on information provided by Bilstein in Mooresville, NC. This is not my opinion or fact, nor am I stating it is. Other factors, such as tires, rim size/weight, and other modifications done to your car might have varied results.
-Mike
Im sorry, but having an Aston Martin DB9 on the drive and not driving it is a bit like having Keira Knightley in your bed and sleeping on the couch. If youve got even half a scrotum its not going to happen.
-Jeremy Clarkson
Messe46 is offline   Reply With Quote
Old 12-08-2010, 03:49 PM   #2
SamDoe1
My Ride: 4cyl of fury
The fact that there is less room to move the fluid doesn't matter. The fluid is incompressible no matter if you have an ounce or a gallon. It's all about the orifice (valve) that the fluid travels through. The shorter body just means there's less travel distance.
Good research though!
Old 12-08-2010, 04:47 PM   #3
Glissco27
My Ride: is a smoked Xi
Send a message via AIM to Glissco27
OP so what shocks do you think you'd get? i wanted a bilstein sport/HR sport combo but now with that warranty thing idk what to do
Khoalty Black Matte Grill | Khoalty Smoked Turn Sig w/ LEDs | Khoalty Smoked Side Markers w/LEDs | Silver CF Vinyl Interior Trim | Khoalty LED Interior Kit | CF/White Roundels | Khoalty Smoked Tail Lights | Khoalty Angel Eyes | Aftermarket Pioneer sound system
***Wants***
M-tech II front Tiag
Glissco27 is offline   Reply With Quote
Old 12-08-2010, 04:52 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
sticky worthy i think.
Do you ride a sportbike?
Old 12-08-2010, 10:00 PM   #5
Kubica
My Ride: 2003 325xi
I had a nice chat with a Bilstein rep at the Bavauto show'nshine this year- he specifically mentioned three separate times that the HD's for the xi are good for up to a .75inch drop.
I don't know of springs that give that small of a drop, but that's where the cutoff line is.
Old 12-09-2010, 06:49 AM   #6
lotar_6
My Ride: '01 xi, '94 Rado
He stated the warranty would be void for HD's on lowering springs... not sports on lowering springs.
lotar_6 is offline   Reply With Quote
Old 12-09-2010, 09:48 AM   #7
SamDoe1
I don't know if this is stated or clear on this one, but the shocks/struts do not contribute very much to at all in lowering a car. They are simply the damper in a mass(car)-spring(obvious)-damper(shock/strut) system. The springs are the only thing which will lower your ride height. The dampers only reduce the oscillation (bounciness) of the spring. The reason you can't use the longer shocks on short springs is because they will always ride in a low position which will eventually blow the valves because they aren't designed to operate for extended periods of time at such pressure.
