Old 12-09-2010, 12:13 PM   #1
nenadv99
My Ride: BMW 318i E36
door actuator replacement
hey guys..
i have a problem with drivers door lock and actuator on my 320CI 2001., i have to replace it with a new one.
the parts owner asked me is my door lock "code" or without "code" and i didn't know. i don't even know what he is talking about
Do you know what kind of actuator do i have, code or no code?
here is my VIN if it helps: JV52104
TNX
nenadv99 is offline   Reply With Quote
Old 12-09-2010, 01:07 PM   #2
rowdy lee
My Ride: 2000 323ci
um...
On an E46, I think the driver's door lock unit is the master, or main unit for the entire car.
Perhaps "code" is referring to the auto lock-unlock feature programmed to go with your ignition key.
Not at all sure... sorry.
Why didn't you ask the parts person what they were talking about?
I'd buy it in a heartbeat... if only I wasn't living on the moon!
rowdy lee is offline   Reply With Quote
Old 12-10-2010, 04:16 AM   #3
nenadv99
he doesn't know either, he has only two listed in his stock, with code and without it.
on coupe you can't unlock the car with key on passenger doors so it must be the master lock on drivers side like you said...
i'll buy the code one, just praying god that gm5 module is fine...
tnx man
Old 12-10-2010, 05:11 AM   #4
paraklas
My Ride: ESS TS2 320ci
There are two part numbers for the door lock actuator, left or right. Based on your vin:
Door swivel handle, front (from 09/00) - BMW parts catalog
Actuator DIY
Item 1
Edit: Are you sure it's the actuator and not a key barrel or GM module? What are the symptoms????
Old 12-10-2010, 07:31 AM   #5
nenadv99
Actuator DIY
Item 1
i am not sure what it is, i just hope that is actuator. its easier to replace whole lock instead of gm5 module...
i can lock the car with remote but when i unlock it only passenger door unlocks, drivers stay locked.
with the key i can lock and unlock driver door normally...
its the same problem like in that video you posted on your thread.
Old 12-10-2010, 10:46 AM   #6
RoadRacer1995
My Ride: 2001 330ci
It has to be it #1 - the power door lock module. Mine went out last year. It lost it's strength to unlock & push the tiny knob up. Once replaced, everything was OK. Code shouldn't come into play for this part. So I don't know about that subject.
RoadRacer1995 is offline   Reply With Quote
Old 12-10-2010, 11:22 AM   #7
WFRFitness
My Ride: 2000 328CI E46
Yep it's #1 but make sure you try this first: http://forum.e46fanatics.com/showthr...060&highlight= I had trouble opening my door and it wouldn't lock or unlock at times. Was about to click the button and purchase a new lock assembly but after doing this works perfectly. Only took 5 minutes and saved me $100+ and lots of time replacing the lock assembly myself.
WFRFitness is offline   Reply With Quote
Old 12-10-2010, 12:15 PM   #8
nenadv99
tnx guys for the answers...
i'll try the bolt thing first, maybe that helps...
i took off whole lock yesterday and return it and now i cant lock and unlock with key at all, i can't even turn the key left or right, like its stuck
did i broke something or i have to pay more attention when i put the lock back?
